Old 02-07-2018, 01:31 PM   #1
nicpaige
Plumbing forums no replies so I'll try here
Hello everyone. I currently am combining two bedrooms into one and taking the 1/2 bath in the master and making it a full bath with walk in shower. The big issue is this is a slab ranch house. So demo of the slab is necessary. I have attached a print of the project. My question is how I plan on routing the drains for new shower and vanity. Please advise if its all messed up or changes to make things better to plumb...thanks again.
I live in Ohio if that matters. Basically the plan is to expose the toilet waste line and cut the cast pipe out, tie in a PVC with fernco and t- off that to pickup the shower drain. The sink drain will be picked up by the shower line with a wet vent.
Paige
nicpaige is offline   Reply With Quote
Old 02-07-2018, 01:55 PM   #2
GHR
What "plumbing forum" did you try?
The biggest one I know of is : http://terrylove.com/
The folks here will help you out though.
I'm Henry
Money talks alright... All ever says to me is "Goodbye!"
GHR is offline   Reply With Quote
Old 02-07-2018, 06:17 PM   #3
Carbidetooth
Hmmmmm
Carbidetooth's Avatar
Hard to tell from your drawings, but generally wet vents are not allowed by ahj. Even if they were or if job not being inspected I'd look for alternatives.
Can't tee into horizontal waste lines, should use wye so there's more of a sweeping transition.
If walls are uncovered photos of existing would help. Vents can be tied together in attic. I'd be looking for a way to vent the vanity and shower separately close to drains. Usually 5' considered max.
Where is the vanity vent?
Peter
Old 02-07-2018, 06:22 PM   #4
Don't think that you have acceptable venting in that scheme. Generally, if I understand it properly, if say your shower was vented properly, you could wet vent the toilet from it, but the toilet flow going past an unvented shower would suck that trap dry.
Old 02-08-2018, 05:25 AM   #5
nicpaige
Thanks for the replies. I did post on the terry love forum with no responses.
Paige
Plumbing Forums? austinpower Tile Forum/Advice Board 5 02-21-2010 08:57 AM
JB Forums John K Computer Training 15 10-14-2009 08:21 PM
New Guy to the Forums ckl111 Professionals' Hangout 10 09-09-2007 09:22 AM
Other forums? JimC Tile Forum/Advice Board 3 04-15-2005 11:52 AM
massive replies Davestone Tile Forum/Advice Board 27 04-21-2004 06:19 PM
