Old 02-06-2018, 09:53 AM   #1
GOGO
Substitute non Schluter wire
Can we use another 220 wire instead of Schluterís in their Duo product. seems it should work the same. Thanks
RL
GOGO is offline   Reply With Quote
Old 02-06-2018, 11:01 AM   #2
GHR
There are tech sheets for their Schulter Ditra HEAT-DUO here:
https://www.schluter.com/schluter-us...DITRA_HEAT-DUO
Perhaps they will help you.
I'm Henry
Money talks alright... All ever says to me is "Goodbye!"
GHR is offline   Reply With Quote
Old 02-07-2018, 02:24 AM   #3
The spacing and wattage/foot of the cable along with the total diameter would determine whether it would work, and how well it would snap into the mat. If the wire and insulation was a bit smaller, it might not stay in the groove. If it was too big, it may be either really hard to get it in there, or it may pop out on its own and in a worst case scenario, it might stick up above the mat making it messy to try to spread thinset or set tile without issues. You'd probably want to use the thermostat designed for the cable in use, but the Schluter one MIGHT work properly. It's a good idea to install a redundant floor sensor in case one (eventually) does go bad. Schluter includes one with the thermostat and another with each cable assembly, so you'll always have at least two you can install.
Substitute Kerdi Cloth jmedgar Professionals' Hangout 18 07-08-2013 05:44 PM
speedset substitute Navilluso Professionals' Hangout 16 12-01-2007 08:01 AM
Wire Heat Cable And More Wire cabela Professionals' Hangout 3 08-19-2005 11:22 AM
Would a 45 be a good substitute for bullnose? kevreh Tile Forum/Advice Board 17 02-26-2002 02:00 PM
Substitute for plywood as an underlayment? Michelle Tile Forum/Advice Board 8 08-20-2001 06:52 AM
