Old 02-05-2018, 09:59 PM   #1
stubbySpider
Repair cracked ceramic corner shelf
Hi
My ceramic comer shelf in my shower just broke. I have cleaned the corner up and there is only dead thin set left in the recess.
Could you please take a look at the pictures attached?
  1. how can I take the dead thin set out?
  2. how can I make it look OK(not an eye sore) and water tight again?
Your help is much appreciated!
Stubby Spider
stubbySpider is offline   Reply With Quote
Old 02-05-2018, 10:03 PM   #2
Stubby,
Welcome to the forum.
From what we can see of the previous install, I highly doubt there is any way to make this waterproof. Unless there is sheet membrane behind the ceement board, you're SOL in the waterproof department.
That being said, I' take a cold chisel and hammer to the thinset and carefully chip it away, allowing enough room for new thinset and a new corner shelf.
Can you remove the escutcheon plate at the shower faucet and take a picture of the cross section of the wall assembly?
Old 02-05-2018, 10:06 PM   #3
They sell the same shelves at Daltile and other places
Old 02-06-2018, 04:15 PM   #4
stubbySpider
Thank you Paul. I asked my builder that is not water proofed. I think I will install a new one as you suggest.
Stubby Spider
Old 02-10-2018, 02:07 PM   #5
stubbySpider
Today, I bought a similar shelf and type 1 mastic. The Lowe's guy said I could use it for the shelf. I read the instructions. He seems to be right because the shelf will not be submerged or receive any standing water. Would this be OK? Or must I use ceramic mortar?
I will also caulk the edges so that it is air tight. Should I use Silicon for caulking?
Stubby Spider
Old 02-10-2018, 02:14 PM   #6
I would not use mastic in that application. Most of the big box stores sell 10lb. bags of thinset powder that you mix with water. Use that, and some masking tape to hold it in place overnight. Make sure it's sloped so that water doesn't stand on it.
You can use silicone for aesthetic purposes where the dish meets the wall.
Old 02-10-2018, 02:17 PM   #7
While theoretically, the product you have would work okay in ideal conditions...
Judging from the relative large thickness of the old mortar, you're exceeding the thickness capacity of that mastic. That's the deal breaker for me. A real live mortar that you have to mix with water will be stronger and able to handle the thickness of bonding material you seem to require.
Yes, silicone is a great sealant to use around the corner shelf.
EDIT: Kevin's got faster finger than I today.
Old 02-10-2018, 03:53 PM   #8
Another vote for powdered thinset that you mix with water. Take the mastic back.
Old 02-11-2018, 09:48 AM   #9
stubbySpider
Thank you all for your insight. I am exchanging it with mortar. Hopefully, I can find a small bag.
Stubby Spider
Old 02-11-2018, 01:33 PM   #10
stubbySpider
Just bought this from Home Depot. 1.5 pounds is the smallest I can find, which is perfect for my use case.
Stubby Spider
Old 02-11-2018, 01:50 PM   #11
That'll work.
Ceramic corner shelf question falstaff Tile Forum/Advice Board 14 01-12-2017 06:43 PM
Broken (not cracked) corner ceramic shelf lsiravi Tile Forum/Advice Board 6 03-02-2013 08:42 PM
repair a corner tile shelf cherlk Tile Forum/Advice Board 1 10-17-2011 12:44 PM
Need advice on installing ceramic corner shelf nastafarian Tile Forum/Advice Board 4 01-06-2009 08:51 PM
shower corner shelf repair reedstrm Tile Forum/Advice Board 9 02-08-2005 10:06 PM
