Old 02-05-2018, 08:11 AM   #1
JPG-WNY
Vent pipe in wall
I am replacing a fiberglass shower with a new tiled walk in. I found this vent pipe which breaks through the bottom plate. The water lines also are very close to the edge of the bottom plate.
I was going to install blocking all around but how do I handle this?
Should I attach furring strips to existing studs or perhaps use a 1" thick Kurdi board and hollow out the back side a bit.
I am planning on using the Schluter tray and I will need to dry pack around it.
Will the Kurdi board be enough support if I put it in first with no blocking?
Jim
JPG-WNY is offline   Reply With Quote
Old 02-05-2018, 09:21 AM   #2
Hi Jim,
It looks like thin furring strips will get you out past the vent pipe. And you don't need solid backing if you're using Kerdi-board. Just fur out the bottom plate the same as the studs, and bring the Kerdi-board all the way down to the subfloor. Then install your tray.
Handling buried vent pipe in shower bed Mike_Qtile Tile Forum/Advice Board 16 01-10-2018 04:47 PM
Advice for dealing with interfering drain vent pipe nick9871 Tile Forum/Advice Board 16 09-18-2016 12:23 PM
Wall vent exhaust fan? TileArt1 Professionals' Hangout 11 06-27-2010 05:50 PM
Help-I may have screwed Durock to PVC vent pipe StarTRavel Tile Forum/Advice Board 15 03-02-2005 01:17 AM
Moving drains and vent pipe rob@netlumina.com Tile Forum/Advice Board 9 05-20-2004 07:57 PM
