Old 02-06-2018, 10:23 AM   #31
gyouska
So I should used un modified thin set to stick the porcelain tile onto the ditra. Even though you are suppose to normally use modified to stick porcelain?
Steve.
gyouska is online now   Reply With Quote
Old 02-06-2018, 10:54 AM   #32
Yes, unmodified over Ditra. Modified would be okay if you wanted to allow extra days to dry, but unmodified will work. Use the flat edge of your trowel to skim a thin layer over the back of each tile immediately before it's set.
Steve, if you'll add your first name to your permanent signature line, where you have the numbers and letters, it'll appear on every post.
Old 02-06-2018, 10:57 AM   #33
gyouska
I am trying to edit my signature line. but that sounds good. I was told from my tile supplier they sell mapei ultra flex 1 and ultra flex 2 which are both modified to stick ditra. does it make much difference on what bag I use. flex 2 is suppose to have more polymer added for extra stickyness. will ultra flex 1 work well enough also?
Steve.
Old 02-06-2018, 07:43 PM   #34
Yes, Ultraflex 1 will be fine.
Old 02-06-2018, 07:59 PM   #35
Are you installing actaul Ditra or the KeedeRoll 100 uncoupling mat you talked about yesterday?
Old 02-06-2018, 08:08 PM   #36
gyouska
I will be using ditra.
Steve.
Old 02-06-2018, 08:18 PM   #37
Great choice. I looked that other product up and was not impressed by their website that was peppered with mistakes.
Old 02-09-2018, 09:41 AM   #38
gyouska
I was at a job site today and noticed the tile guy installed the ditra under layment. I took a couple photos. I notices he skimmed the ditra with a layer of mud and he left it to dry so he could come back a different day to set the tile. What is with the skim coat on top of the ditra? all the info I have seen everyone just starts setting the tile right onto the orange side. Is there any reasoning behind this? is it necessary? also I took a photo of the bag of mud he used. It appears to be a modified thinset? I guess it is what he used to stick the ditra to the plywood and I assume its the same stuff he used for the skim coat. any feedback?
Steve.
Old 02-09-2018, 09:46 AM   #39
Obo2
It seems pretty common to go ahead and use the extra modified from laying the ditra to fill the waffles. Less waste and less pushing thinset around when you are trying to lay tile.
I guess the process has been okd by schluter as long as you give it time to dry.
Nick
I probably have no idea what I am talking about.
Obo2 is offline   Reply With Quote
Old 02-09-2018, 10:03 AM   #40
gyouska
how necessary is this to do? and would I use the unmodified to set the tiles even tho I used the modified to fill the waffles? Is the advantage just to fill the waffles so you are not spending as much time trying to fill them when setting tile?
Steve.
Old 02-09-2018, 10:12 AM   #41
Obo2
It's not necessarily and probably not really preferred.
Yes you would still use unmodified to set the tile.
It's just to make less work later. It's also fairly convenient as it doesnt take much to set the ditra so you are likely to have leftover. It also makes snapping chaulklines a little easier.
Nick
Old 02-09-2018, 10:39 AM   #42
gyouska
ok for sure snapping a chalk line was a concern I had as I have never worked with Ditra. sorry for the excess questions I am just trying to make sure. so I would use the modified to fill the waffles if I decided to do it that way?
Steve.
Old 02-09-2018, 10:39 AM   #43
diddly
Mud it
See my earlier post today. 3/4 inch thickness of tarpaper and wire and mud bed over the high spot is more than sufficient for a lifetime floor. Make sure the installer is actually fully competent in laying a mud floor and have him do the job.
bookie
Bookie
diddly is offline   Reply With Quote
Old 02-09-2018, 10:41 AM   #44
gyouska
would you mix the thinset a little on the runnier side? to help fill the waffles? also what is it like trying to snap a chalk line on the Ditra? I heard something about hairspray. what works?
Steve.
Old 02-09-2018, 10:42 AM   #45
Obo2
They show in some of their videos that you can spray the chaulk line with hairspray to make it stay.
I'm sure you could do it with unmodified too but most people have extra modified mixed up from laying the ditra.
It really didn't work at all for me to snap chaulk on ditra. I used a sharpie and a long straight edge in the one room i didn't prefill the waffles in.
Nick
Choosing the right underlayment. zakos Tile Forum/Advice Board 14 08-08-2011 02:08 PM
Choosing contractor LadyGodiva The Mud Box 17 11-17-2009 10:22 AM
Choosing an equivalent Architect_stuff Professionals' Hangout 14 02-17-2009 07:07 AM
Choosing A Tile Saw MarshallHouTx Tile Forum/Advice Board 4 03-04-2006 04:13 PM
help choosing a floor underlayment strawbie Tile Forum/Advice Board 10 08-09-2002 04:35 PM
