Old 02-04-2018, 09:02 AM   #1
walldocmp
Is a shower curb with a grout joint down middle ok?
Hi all,
I will be tiling a shower curb. I know a solid piece on the top of the curb would be best. However using the trim tiles i have my question is which would be better having a grout joint down the middle or two out at the edges as shown in the two pictures below. Or are they both equally bad?
I built the curb as describe in the john bridge website with 2x4s, pvc liner, lath and masonry mix.
walldocmp is offline   Reply With Quote
Old 02-04-2018, 09:20 AM   #2
evan1968
Not So Senior Contributor
evan1968's Avatar
Either is ok Mike if the curb is constucted properly which it sounds like it is. What does Mrs Mike prefer? I would defer that question to her.
With the outside joint like the second pic, depending on the width of the bullnose, you might need profile metal for the outside and inside edge.
Personally I like a solid surface threshold on top of the curbs I do but that's just me.
Craig
Commercial Tile Installations
KEEP CALM and TILE ON
Old 02-04-2018, 11:36 AM   #3
There's no way the pitch on the second pic curb is 1/8 like it should be. Without miter cuts, you can pitch the top of the curb very much. It makes a clean look but the pitch is more important.
Like Evan said, the waterproofing is under the tiles so either will work. We've done both many times.
Old 02-04-2018, 11:58 AM   #4
wwhitney
It is mathematically possible that the unmitered corner tile is set at an angle so that each end of the tile is sloped 2% in a plane transverse to the curb. Those 2 lines determine a plane in which the tile would have to lie, meaning the inside and outside edges of the tile wouldn't be level, causing many further complications.
I agree it is far, far more likely that the top of the curb pictured is level.
Cheers, Wayne
Wayne
Old 02-04-2018, 12:22 PM   #5
A flat piece of tile can be tilted but there's no way to keep the inside and outside edge level and inline with the other pieces on the curb. The tiles would need to bend to do that. You might hide it with only a 1/32 pitch or maybe a 1/16 but a curb needs more than that.
Old 02-04-2018, 01:09 PM   #6
walldocmp
Makes sense. Hadn't thought about the corner issue. Thanks for the heads up and the help.
-Mike
Old 02-04-2018, 02:49 PM   #7
wwhitney
Sounds like we are in agreement.
Cheers, Wayne
Wayne
Old 02-04-2018, 04:08 PM   #8
I think so, I missed that part of your post. Sure would help sometimes if tiles would bend.
in the middle of shower remodel karlabthremodel Tile Forum/Advice Board 87 06-13-2017 09:01 AM
Starting from the middle (new shower) curiousburke Tile Forum/Advice Board 21 07-22-2015 06:28 AM
cold joint at floor-to-curb connection Kaz Tile Forum/Advice Board 5 04-22-2012 08:39 AM
Shower curb tile - is butt joint okay? drfarley Tile Forum/Advice Board 9 02-28-2007 03:18 PM
Stuck in the middle of a shower stall BruceC Tile Forum/Advice Board 8 09-23-2003 06:00 AM
