Old 02-03-2018, 09:49 PM   #1
galex1523
Pebbles shower floor
Hi every one..
I did a shower where the homeowner wanted pebbles on the shower floor, that was the first shower floor where I used pebbles, and at that time I didn't have much info about grouting pebbles. Do After About 6 Months OF finished That SHOWER Some Cracks developed On the grout causing the shower floor Look wet for Long time. At the time I grouted the pebbles I used mapei sanded grout, and grout sealer.
So I had to remove the pebbles and redo the shower pan as a warranty, now I'm about to grout pebbles again but I'm not sure what type of grout to use, I've heard that epoxy grout is the best in this cases due to the big grout spaces between each pebble.
Any suggestions? Thanks in advance
Alex
galex1523 is offline   Reply With Quote
Old 02-03-2018, 10:57 PM   #2
Alex,
Spectralock, Fusion Pro, or Flexcolor will all work very well.
For rounded pebble floors, the pitch should be 1/2" per foot to allow better surface drainage.
Old 02-04-2018, 06:06 AM   #3
Karls tile Inc
Tile and stone contractor Tile setter
Don't use flex color to grout the pebbles. Mapei says that the joint width on pebbles exceeds the capability of Flexcolor.
Karl
Karlstile.com
Karls tile Inc is offline   Reply With Quote
Old 02-04-2018, 12:29 PM   #4
nelsonkoehn
showers & more
nelsonkoehn's Avatar
With Mapei, I prefer to use UltraColor Plus over FlexColor CQ for pebbles. Or any natural stone, for that matter.
FlexColor CQ will shrink down considerably on the wide spacing between stones.
Nelson
tile.nkoehn.com
nelsonkoehn is offline   Reply With Quote
marble shower floor pebbles docmom613 Tile Forum/Advice Board 6 12-28-2012 01:15 PM
pebbles from the beach for shower floor aaron0593 Tile Forum/Advice Board 6 02-24-2012 10:26 PM
Pebbles on the shower floor? ghostcrab Tile Forum/Advice Board 23 11-14-2008 09:51 PM
Inset pebbles-shower floor dlcooper Tile Forum/Advice Board 19 09-17-2003 06:15 PM
Waterproof shower floor with pebbles sdevlin Tile Forum/Advice Board 18 10-20-2001 05:06 PM
