Old 02-02-2018, 09:07 AM   #1
renue74
unmodified mortar between plywood subfloor and Ditra
I accidentally used Latricrete 317 unmodified thinset to put Ditra on a plywood subfloor.
Will it be OK?
renue74 is offline   Reply With Quote
Old 02-02-2018, 09:26 AM   #2
HS345
Tile Contractor
HS345's Avatar
Probably not, unfortunately.
How big of an area are we talking?
The name's Greg
Old 02-02-2018, 10:10 AM   #3
Yeah, I agree with Greg. I wouldn't depend on it.
Old 02-02-2018, 11:21 AM   #4
Shady at Best
Tyrone shoelaces
Shady at Best's Avatar
Many people have had good luck pulling up ditra that has only been installed for less than 48 hours.
Pull it up, clean the ditra with a high power nozzle on your garden hose. Or use new ditra.
Sent from my SM-G935V using Tapatalk
Travis
It's just a clever handle.
Old 02-02-2018, 03:11 PM   #5
renue74
I pulled up the Ditra today during my lunch break. The mortar was still fairly damp.
I scraped a lot of it off the subfloor and I will go back tonight and spray the back of the ditra sheets.
Schluter said it would be OK to reuse the Ditra.
I'll reinstall it tomorrow with modified thinset mortar.
Old 02-02-2018, 05:48 PM   #6
As long as the fleece on the back is intact, you'll be able to get a bond.
It would have been much better to hose the Ditra off instead of waiting!
Old 02-04-2018, 10:08 PM   #7
renue74
Friday night I went back over and installed the ditra with a latricrete 253 mortar.
It was basically a small bathroom and laundry/mud room area...but still took me about an 1 hour to clean up the old mortar and get as much as a can off the Ditra.
I went back and laid tile Saturday. Before I started, I checked the ditra and it had adhered to the floor...so I'm hoping it's good.
Old 02-04-2018, 10:14 PM   #8
Obo2
That looks really nice.
Nick
I probably have no idea what I am talking about.
Obo2 is offline   Reply With Quote
Old 02-04-2018, 10:37 PM   #9
Lou_MA
Not sure if you're aware ditra has a minimum tile size of 2" x 2". Schluter's concern is tiles smaller than that might mainly be sitting on the hollow ditra ribs, and a point load may cause it to compress.
Lou
Old 02-05-2018, 01:43 AM   #10
You really should have used cement board as your underlayment. Will you have trouble because of those 1" pieces? I can't say for sure. I do know, however, that you probably aren't that keen about starting over again.
Old 02-05-2018, 11:54 AM   #11
renue74
Umm..yeah. I'm not starting over.
I'm going to grout next weekend.
It's a college rental house. If it starts causing issues, I'll fix it then.
Old 02-05-2018, 06:01 PM   #12
I'd consider using an epoxy grout. It's bond to the tile edge is stronger, and might help prevent a failure, but certainly won't guarantee it. It will make the tile appear to be larger, spreading any point load out. Bare feet, or normal shoes probably wouldn't be an issue, but someone in high heels will put an enormous point load on the tile...if it's not large enough to span enough thinset pillars, it could tip and/or crack.
Old 02-05-2018, 06:20 PM   #13
renue74
Thanks! I'll definitely try the epoxy grout.
Accidentally used unmodified mortar between plywood subfloor and Ditra Jerry 321 Tile Forum/Advice Board 8 05-08-2015 11:55 AM
Unmodified mortar ,ditra on advantech plywood Mstewart766 Tile Forum/Advice Board 4 05-18-2014 09:20 PM
What is needed between plywood subfloor and preslope mortar? cer Tile Forum/Advice Board 4 11-30-2006 10:34 PM
Ditra mortar- what is unmodified? jdkimes Tile Forum/Advice Board 24 09-29-2006 03:56 PM
confusion about ditra and unmodified mortar DonH Tile Forum/Advice Board 14 02-17-2006 04:36 PM
