Old 01-30-2018, 08:23 PM   #1
AnnLM142
Should tile be cleaned before using Flexcolor CQ grout?
Tile is installed throughout my small home and the spaces between them cleaned of whatever was used to lay them, but the tile tops are filthy. I understand that the first step with Flexcolor CQ is to wet-wipe the tile section you're about to grout and the mfgr. emphasizes keeping sponges clean, so I imagine the tile tops must be clean before starting... is this correct? If so, should I insist, even if I have to clean it myself? Is a general spray cleaner okay? No sink or warm water yet, just cold water from the main line.
Ooops, is warm water needed for the immediate clean-up as the grouting is being done?
Thanks, Ann
Ann
AnnLM142 is offline   Reply With Quote
Old 01-30-2018, 08:34 PM   #2
If the tile aren't clean, you may have a much harder job of cleaning things up after the grout is installed, especially if any of that dirt may be thinset.
You don't want to get a cleaner in the gaps that will need to be grouted, as it could mess some things up. I'd first try a damp mop and see what things look like. If that doesn't clean things up, come back for plan B.
Old 01-30-2018, 08:58 PM   #3
AnnLM142
Thanks, Jim. Glad you mentioned not using cleaner.
Ann
Old 01-31-2018, 12:11 AM   #4
Obo2
Vacuum with both the floor brush and then crevice tool and then wipe down with damp sponge rinsing frequently.
Nick
I probably have no idea what I am talking about.
Obo2 is offline   Reply With Quote
Old 01-31-2018, 11:47 AM   #5
AnnLM142
Guess it's not a good idea for me to do any of this, as then I'd be responsible if there was any problem.
Ann
Old 01-31-2018, 01:28 PM   #6
Definitely not. Let the installer do his job, provided he's not doing something glaringly wrong.
Old 01-31-2018, 03:29 PM   #7
Karls tile Inc
Tile and stone contractor Tile setter
I would ask the installer if he has ever used flex color CQ. Its not like normal grout at all.
Karl
Karlstile.com
Karls tile Inc is offline   Reply With Quote
Old 02-01-2018, 09:57 AM   #8
AnnLM142
Karl: Of the two guys doing most of the tiling (GC and one he defers to on tile), one has never used it (GC) and the other has used it once. I copied excerpts from the entire Flexcolor thread with others' experiences and tips and (gently) offered that "in case they might be interested"... the GC was openly resentful... I highly doubt they'll look at it.
For myself, even when experienced in an area (not construction!), I've actively sought out info from peers and in general gathered all the info I could find when embarking on a project. I'm retired now, but I take that approach in non-work matters too.
I so admire the pros on this forum who take the time to exchange info/advice/ideas, want to stay updated and improve their knowledge and skills. It's a self-motivated continuing education program for tiling experts!
And you are also generous in helping others.
Ann
Old 02-05-2018, 08:18 AM   #9
MAPEI - Technical Service
Company Representative
Ann, good job doing your homework to get the best results. Yes, the contractor should clean the tile before grouting, regardless of the type of grout used. Whatever is on the tile mixes with the grout as it gets pushed into the grout joints. When I install Flexcolor, I clean the tile the night before with water and then allow it to dry. A quick wipe with a damp (not wet) sponge and the tile is ready to grout. Cleaning the grout as you go instead of letting it sit and then coming back to clean it later is the important difference between Flexcolor and a cement grout. Feel free to call our number below or have the GC or installer do so if you need any additional info about the product or process.
http://www.mapei.com/US-EN/
MAPEI - Technical Service is online now   Reply With Quote
Old 02-13-2018, 09:23 AM   #10
AnnLM142
Dan, Belated thanks. I read your post earlier but didn't acknowledge it.
Ann
Mapei flexcolor cq vs customs prism vs grout additive? Shady at Best Tile Forum/Advice Board 2 03-18-2016 10:27 AM
Acid-cleaned old tile floor - DAMAGE! MaryO Cleaning, Restoration and Sealing 5 02-25-2010 11:11 PM
How can I restore shine to ceramic tile I cleaned with scratch pad? rbouton Cleaning, Restoration and Sealing 7 12-29-2009 01:19 AM
I've cleaned this new tile for a week straight! jbcteacher Cleaning, Restoration and Sealing 2 11-02-2008 08:18 PM
Does new grout need to be cleaned before sealer is applied? hi50 Tile Forum/Advice Board 5 04-14-2004 07:43 PM
