Old 01-30-2018, 09:37 AM   #1
Mark AZ
HELP-Sealed Marble Shower Floor-Oops?
I sealed my mosaic marble tile shower floor, and now it takes several days of non-use to completely dry. Please see picture, note area around drain. Am I doomed to replace, or do I just let it go like this? Before I sealed it, it would dry overnight. I sealed it because of a previous experience where a walk in shower floor leaked. Thought I was doing the right thing, but now maybe a big mistake?
What do the experts say? Thank you in advance for any advise you can provide.
Mark AZ is offline   Reply With Quote
Old 01-31-2018, 07:09 PM   #2
Welcome to the forum, Mark.
A high alkaline pH ceaner will generally strip the sealer. I’d give your sealer manufacturer a call as they may tell you precisely what would strip the sealer the fastest.
Old 01-31-2018, 09:56 PM   #3
The sealer would have no effect on a leaking shower, except to make it easier to clean.
Old 01-31-2018, 11:01 PM   #4
...and what Kevin said.
Old 02-02-2018, 02:55 PM   #5
Mark AZ
Thanks everyone! That’s good news.
Mark
Old 02-04-2018, 02:07 PM   #6
stu rosen
It appears to be a moisture issue around the drain.
I have seen this happen with marble mosaic installs in shower stalls.
There isnt any simple fix here.
Moisture is wicking up into the stone. Sealing from above will just make it take longer to dry out. I think the specification of the stone and the drain type could be the issue.
Stu
www.stoneshine.com
stu rosen is offline   Reply With Quote
Pebble tile recently installed on shower floor, never sealed.. oke Cleaning, Restoration and Sealing 5 10-10-2012 06:27 AM
installing non sealed, non filled tumbled marble vanbiso Tile Forum/Advice Board 2 09-02-2007 05:15 AM
Umm... oops. Sealer on shower floor. ForeEyes Tile Forum/Advice Board 1 11-14-2006 09:17 AM
Floor tiles on shower walls - should they be sealed? TJ Tile Forum/Advice Board 3 01-04-2005 07:33 PM
Sealed honed marble and now it has streaks. jberry Cleaning, Restoration and Sealing 16 09-21-2004 10:27 PM
