Old 01-28-2018, 07:54 PM   #1
Karls tile Inc
Tile and stone contractor Tile setter
Dry cut blade
What is your go to dry cut blade? I have used Alpha Katana blades for sometime. I have also used Diamax mesh blades when I can get them. Has anybody used Montolit dry cut blades?
Karl
Karlstile.com
Karls tile Inc is offline   Reply With Quote
Old 01-29-2018, 06:45 PM   #2
Wish I could help you more, Karl. I don't really have a go to blade. For some reason every time I need one I have to buy whatever is available. I've had the same blade on my grinder for at least a year and I have no idea what brand it is.
Old 01-29-2018, 06:56 PM   #3
reefone
tile setter
ive tried alpha blades. both the 4"dry and the 10" in my dewalt. I'm not a fan of either. I thought the cuts where too rough. now I just use a contunious rim blade from hd. rigid I think.
I'm like davy my grinder blades are on for a year or so cause we don't do a lot of dry cutting. just for toilets and floor drains.any cut that is going to be seen usually gets cut on the wet saw. my go to blade for the wet saw is the pearl p4.
Jerry
tile setter 12yrs exp.
Old 01-29-2018, 08:06 PM   #4
smifwal
I have had good luck with the one in the first photo and the second one is curved makes cutting shower valve, toilet flange and floor drains a breeze. I didn't buy the curved one from that website it was just the first picture that came up. I found it somewhere else cheaper. If you are interested in getting 1 I will look through my email and figure out where I got it from
Old 01-29-2018, 08:25 PM   #5
Karls tile Inc
The mesh blades are the best in my opinion. You can make a cut with them and literally touch the blade after cutting and the blade won't feel hot.
Karl
Karlstile.com
diamond tile blade to sharpen carbide saw blade? argile tile Professionals' Hangout 5 02-19-2017 04:50 PM
Blade Bow snow1wake Tile Forum/Advice Board 6 10-10-2007 09:13 PM
Is it the saw or the blade? Chris H Tile Forum/Advice Board 9 09-05-2006 05:45 PM
Wet Saw Blade Ed-diy Professionals' Hangout 5 07-22-2006 10:55 PM
Wet Saw Blade val77 Tile Forum/Advice Board 14 10-10-2003 10:39 PM
