Old 01-27-2018, 09:59 PM   #1
mark the tile guy
Stains on un sealed porcelain tiles
I have installed a un sealed porcelain tile in a bathroom. I used kerdi bond un modified thinset and did a thorough clean up right away after install. When i went to seal it i could see water stains and foot prints in the light of day. I used heavy duty tile and grout cleaner at strongest suggest mix and it did not lift the stains one bit.
Need to get the stains up before I can seal it and grout it and move on.
perhaps my warning sign should have been that the glue marks from the tile boxes did not come off with a scrubbing either.
Any help would be greatly appreciated,
Mark
mark the tile guy is offline   Reply With Quote
Old 01-27-2018, 10:37 PM   #2
FWIW, most porcelain tile gain no benefit from being sealed...to work, a sealer must be absorbed, and porcelain is pretty impervious. Unless the porcelain is polished (which grinds off the top surface), it doesn't help. Can help on the grout, depending on the type.
Did you follow the instructions precisely on the cleaner? It often takes a bit of time, and elbow grease, assuming it's not something that won't come up at all. Exactly what did you use?
Old 01-28-2018, 04:40 AM   #3
evan1968
Not So Senior Contributor
evan1968's Avatar
You don't seal porcelain. No reason to. Sealer can't absorb into the tile as Jim stated above.
Where did you hear that?
As far as the water marks and footprints go, try barkeeper's friend.
Craig
Commercial Tile Installations
KEEP CALM and TILE ON
evan1968 is online now   Reply With Quote
Old 01-28-2018, 09:19 AM   #4
mullet
mullet's Avatar
That^^^^
chuck
my first Kerdi Shower
Old 01-28-2018, 09:31 AM   #5
Welcome to the forum, Mark!
To help us understand more, can you tell us if your tile is:
1) An unglazed porcelain?
2) A polished porcelain?
3) Or a glazed porcelain?
The product you used is a high alkaline cleaner when it sounds a lot more like you need a slightly acidic cleaner. As a TEST, try dampening a rag with vinegar and clean in one little tiny spot to see if you're getting the results you need. I'd start with a 50:50 solution of water and vinegar. You can increase to full strength vinegar, but it's best to start with the weakest solution that will do the job. Make sure to use a damp rag to rinse off the low acidic pH when you're done.
Old 01-29-2018, 09:21 AM   #6
Hi Mark, All,
A little clarification on Unglazed porcelain tiles. Although porcelain tiles absorb very little moisture, Polished porcelain MUST be sealed. Polishing means grinding, and when the surface is ground the pores are opened. The contaminants actually lodge in the pores. As Kurt mentioned, white vinegar would be the first step. Then use a grout release type product before grouting.
Cleaning grout stains off porcelain tile Govinator3 Cleaning, Restoration and Sealing 7 09-30-2015 09:12 AM
Grout Stains Newly Sealed Shower MaryC Cleaning, Restoration and Sealing 11 04-13-2012 09:07 AM
Porcelain tile stains Labluver94 Cleaning, Restoration and Sealing 3 09-29-2011 05:10 AM
White stains on dark porcelain tile....... JPRicci Cleaning, Restoration and Sealing 3 09-08-2006 04:10 AM
Porcelain 1x1 -- Blotchy Stains from Grout peterson Tile Forum/Advice Board 3 12-16-2002 10:57 PM
