Old 01-25-2018, 09:43 PM   #1
siklife
Installing 3x6 glass tiles.
Hi guys, just wanted to ask for some tips on installing 3x6 glass tiles. The back of the tiles have a white backing, and the edges are see through. Whats the best way to install these to avoid any imperfections showing through the clear edges when looking up or down the wall after the grout is in. From my understanding, you just need to collapse the trowel ridges as you go. What else should i be doing / looking out for.
siklife is offline   Reply With Quote
Old 01-25-2018, 10:07 PM   #2
Karls tile Inc
Tile and stone contractor Tile setter
Use a high quality mortar designed for glass tile. Don't butt joint the glass. I would suggest a 1/8 grout joint. I would also make sure your surface is flat. Lighting can also affect how a glass tile installation will look.
Karl
Karlstile.com
Karls tile Inc is offline   Reply With Quote
Old 01-26-2018, 07:08 AM   #3
tilemanct
Tile & Stone
A good quality glass blade on your saw is a good start. Do a test on the material. Sometimes the backing, no matter how careful you are, flakes off. (Sign of really bad quality) I usually flip the tile white face up and lightly score it with the blade to get a crisp line. Then reverse and do the cut. You can also place some backerboard under the tile and set your saw blade to just go about 1/32" below the bottom of tile and cut. Either way gets you a good cut. I usually have some touch up appliance epoxy on hand just in case the white backing flakes.
CTEF Certified Installer
Old 01-26-2018, 08:41 AM   #4
MAPEI - Technical Service
Company Representative
Definitely flatten your trowel ridges and use a white mortar like our Adesilex P10. Typically for glass tiles we recommend an unsanded grout like our Keracolor U. Make sure not to put too much water in either product, the biggest cause of odd optical 'ghosts' in glass tile is from moisture. If they are going in an area where they may be in contact with water, seal the grout with Ultracare Grout Sealer.
For some extra bling, you can also try our new Flexcolor 3D grout that is translucent and designed especially for glass tiles.
http://www.mapei.com/US-EN/
Installing a glass corner shelf to ceramic tiles bigrick Tile Forum/Advice Board 4 09-23-2009 04:36 PM
Hints for installing Glass Tiles on Walls some canadian guy Tile Forum/Advice Board 23 08-16-2009 09:50 PM
installing glass tiles Amanda Tile Forum/Advice Board 4 12-01-2008 11:21 AM
Installing glass tiles on fiberglass wrbear Tile Forum/Advice Board 1 02-18-2008 08:33 PM
Installing glass mosaic tiles, Need Urgent advice srican Tile Forum/Advice Board 23 08-30-2006 04:07 PM
