Old 01-25-2018, 08:45 PM   #1
lati_cz
michal
adjusting Tilematic
I have Husqvarna tilematic and it cuts slightly off. Any idea how to adjust it?
Michal
lati_cz is offline   Reply With Quote
Old 01-26-2018, 11:24 AM   #2
That depends. I don't have your saw and know which parts are fixed and which parts are adjustable, so I'll talk generically:
If the rail is parallel to the blade, then you're likely needing to twist the tray so the back guide is perpendicular to both the rail and the blade.
If the rail isn't parallel to the blade, then you're likely needing to adjust the rail so it's parallel to the blade.
If the rail is parallel to the blade and the back of the tray is perpendicular to both the rail and the blade, it would suggest your blade is cutting more aggressively on one side than the other and needs dressing.
Old 01-26-2018, 11:59 PM   #3
lati_cz
michal
I found it online. Thank you.
Michal
Adjusting MK-770 tile saw pray4surf Tile Forum/Advice Board 2 06-20-2010 08:53 AM
adjusting for different tile thickness GlenFlowers Tile Forum/Advice Board 10 08-21-2008 06:28 PM
adjusting dewalt 2400 custombuilt Professionals' Hangout 3 05-26-2008 07:41 AM
Adjusting pre-slope? flashpd Tile Forum/Advice Board 5 11-08-2005 07:57 PM
Adjusting for Different Thickness Tiles allencar Tile Forum/Advice Board 13 07-17-2003 10:07 PM
