Old 01-23-2018, 12:29 AM   #16
Time to attend a Schluter workshop. Not to brainwash you or anything. This is about learning the nuisances of what you’re doing. If you’ve got seams that aren’t holding, it’s time to look at what you’re doing.
Yes, some mortars do more than others and allow you to work, excuse the term...sloppier than others without paying a penalty. But if if you’ve got seams that aren’t holding, it’s the operator that needs to be concentrated on...not just switching to a higher dollar mortar. The workshops are free, fun, and every tile guy that attends learns something. No one excluded. Call your local rep to ask. In the mean time, experiment away. Use different mortars on little mock ups. Let them cure and tear them apart to see their strengths and weaknesses.
Go to an Ardex workshop.
And/or Mapei.
And/or Custom.
And.....
Old 01-23-2018, 07:19 AM   #17
Peerless Tile
Tile Contractor
Im a 272 guy when it comes to kerdi...Its that or Kerabond T. Schluter Rep in my area has 10 of each of the new mortars waiting on me to pick up and try. Price of those mortars will keep most informed pros away but I told him Id give them a whirl after this last reformulation.
SC Greg
Peerless Tile is offline   Reply With Quote
Old 01-23-2018, 09:32 AM   #18
Ward
For Ditra we use Laticrete 255 MultiMax below and Bostik Ditra-Set on top.
For Kerdi Board we'll use Bostik Ditra-Set.
We've tried the thinset offerings being made by Schluter, but our guys didn't like them at all. They take too much time to mix and they didn't have the grab that they like.
Ward
Ward is offline   Reply With Quote
Old 01-23-2018, 11:22 AM   #19
Carbidetooth
Hmmmmm
Carbidetooth's Avatar
Greg, do tell about reformulation of Schluter's thinsets. I tried last summer expecting much for $$ spent. Not impressed.
Peter
Old 01-24-2018, 06:04 AM   #20
tilemanct
Tile & Stone
The pallet of Schluter thin set continues to gather dust at my distributor. Everyone who has tried it is unimpressed. We have Ardex, Laticrete, and Mapei to choose from. I think it was a HUGE mistake for Schluter to venture into this arena.
CTEF Certified Installer
Old 01-24-2018, 11:48 AM   #21
dgbldr
Has anyone used Mapei's Uncoupling Membrane Mortar?
http://www.mapei.com/public/US/produ...rtar_EN_lr.pdf
Available at your neighborhood Lowe's. I haven't tried it yet.
DG
Remodeler
dgbldr is offline   Reply With Quote
Old 01-24-2018, 12:30 PM   #22
MAPEI - Technical Service
Company Representative
Like Kerabond T, Uncoupling Membrane Mortar was designed to be used with the membranes on the market that require an unmodified mortar while still giving the thixotropic properties that work well with large and heavy tiles. If you want it modified for use with porcelain, you can add the Polymer Additive.
http://www.mapei.com/US-EN/
Old 01-24-2018, 10:13 PM   #23
dgbldr
Dan, can you comment on how Uncoupling Membrane Mortar is different from Kerabond T? Thanks
DG
Remodeler
Old 01-25-2018, 06:23 AM   #24
tilemanct
Tile & Stone
If you want to stop all the nonsense with mortars, just switch your membrane. Mapei makes one that knocks the socks off of big orange. Modified thin sets are allowed.
Old 01-25-2018, 07:52 AM   #25
DG, we don't disclose the formula differences between the MAPEI products and the Lowes products. However, Kerabond T and Uncoupling Membrane Mortar meet the same specs and are formulated to have a similar feel when you're working with them. If you like one, chances are good you'll like the other.
Dave, thanks for the vote of confidence on our Mapeguard UM! We agree that it's a better mousetrap for a number of reasons.
Old 01-26-2018, 10:00 PM   #26
Pick the right modifier in your thinset, and it works just fine with Ditra or Kerdi. The problem is, the ANSI spec doesn't differentiate it, so it's hard to specify, and manufacturers change formulations without notice, so Schluter doesn't want to specify one that they don't control. Who knows when one new, improved formulation comes out that might have worked before, that no longer doesn't. The liability is too great.
Old 01-26-2018, 10:40 PM   #27
dgbldr
Dan, I thought Mapeguard is for floors only Does Mapei make a wall membrane?
DG
Remodeler
Old 01-27-2018, 09:55 PM   #28
bc brick john
bc brick john's Avatar
my two cents worth here up in the wet PNW
both set and all set peeled off the trowel and every thing else unless really burnt in to both surfaces where coarse and felt very sandy gritty
when set up . all set was super strong
seamed like way to much polymers in the mix ...
gone back to Ardex 5 or my other was mapei's LFT both in white just cause i like white thinset ......
like laticretes stuff but just not ready available where i live ...
John
Senior Lecturer in Brickwork Masonry
Training instructor/Assessor
brick mason & tile setting
www.stonetilegibsons.ca (under construction)
bc brick john is offline   Reply With Quote
Old 02-05-2018, 08:26 AM   #29
Mapeguard UM can be used vertically although typically you would only do so for a few inches at the bottom of the wall, there is even a built-in 7" crease to make it easy to do the up-turn. If you're trying to waterproof a wall, you're much better off with AquaDefense.
Old 02-25-2018, 09:43 PM   #30
fulms
If you really want to treat yourself switch your mat to Laticrete strata mat. There is no make sure you use this mortar here. Modified is good all around use 253 gold because it is gold. On small bathrooms Ive put the strata mat down and start tiling with the same mud. Ive never used Mapei's mat but if they have made one so you don't have to use and unmodified mortar then that's great.
Mitch
fulms is offline   Reply With Quote
Thinset too thick for Kerdi?? Ditra Set?? stevepwlb Tile Forum/Advice Board 3 05-31-2014 12:42 PM
Best thinset for Kerdi and Ditra? handigirl Tile Forum/Advice Board 23 01-21-2010 07:45 PM
Thinset over KERDI............er, um....Ditra Hammy Professionals' Hangout 30 09-02-2009 07:29 AM
What is your favorite thinset for ditra? Racer X Tile Forum/Advice Board 32 04-21-2009 07:35 AM
Best thinset over Kerdi and Ditra tiffanp Tile Forum/Advice Board 8 08-30-2007 09:42 PM
