Old 01-20-2018, 12:41 PM   #1
Shady at Best
Tyrone shoelaces
Shady at Best's Avatar
Your favorite thinset for kerdi and ditra?
I am always searching for better ways to do things. I am currently using customs versabond for my kerdi and ditra installs. Mainly due to the availability. I am also a big fan of ardex x5.
This is not a thread about what schluter recomends using. We all already know that. And the schluter ditra set and all set are horribly to work with.
I am not opposed to using a non modified thinset. I would use one as long as it can hold 2 overlapping pieces of kerdi together after 36 hours of drying.
What do you guys like using?
Sent from my SM-G935V using Tapatalk
Travis
It's just a clever handle.
Old 01-20-2018, 01:05 PM   #2
Lazarus
Lazarus's Avatar
Ditra Set is fine and I'm a fan of it....have been for years. Having said that, I find that the Mapai is a good unmodified as is the Laticrete 317.
Laz...
Old 01-20-2018, 01:23 PM   #3
rmckee84
Tri-lite or x5. This may be a post better suited for the pro's hang out?
Ryan McKee
Old 01-20-2018, 03:38 PM   #4
sycamorebob
Ditra-set all the time. Good to know about's Schluters new products.
" And the schluter ditra set and all set are horribly to work with. "
Patrick
sycamorebob is offline   Reply With Quote
Old 01-20-2018, 10:12 PM   #5
Shady at Best
Tyrone shoelaces
Its been awhile since I used Bostic Ditra Set. I will try that again. I am doing a job where I am installing ditra on plywood. Looks like ditra set is good for that application.
Would a primer make things better when installing ditra over plywood?
I am down for that.
Different question.
Is 1/8x1/8x1/8 still the trowel for KERDI?
Travis
Old 01-21-2018, 08:22 AM   #6
rmckee84
Moved your thread to the Pros hangout Travis.
1. I don't, as long as you hydrate the ply as you go it will be fine.
2. Yes
Ryan McKee
Old 01-21-2018, 08:32 AM   #7
eurob
tile and stone installer
eurob's Avatar
Favorite thin set for kerdi & ditra
Ultraflex RS / Ardex X7R
Roberto
Knowledge -- something you cannot undo once you learn about it --
Old 01-21-2018, 10:36 AM   #8
CaliGrown
CaliGrown's Avatar
Another vote for Laticrete’s 317, easy to work with and I get it for $8.15 a bag. If I want to put Ditra and Tile down the same day I’ll use 253 Gold Rapid, give it a six pack and I’m setting.
Chris
Old 01-21-2018, 01:13 PM   #9
Shady at Best
Tyrone shoelaces
I had a dream about laticrete 317 a few days ago. I think that dream was what sparked this question. In the dream i was buying 317 for 4$ a bag. It was crazy random.
I have been rewatching all the schluter vids for shiggles. ( shits and giggles) They say that you can install ditra and set tile on the same day with no special thinset. Anyone do this?
Another question. Any reason why i couldn't use painters plastic (.9mil) under a mortar shower pan, on plywood, that will be covered by kerdi?
Travis
Old 01-21-2018, 09:45 PM   #10
dgbldr
Do you guys use the 317 unmodified or do you mix some admix in?
Edit: Is this thread about thinset between kerdi/ditra and substrate, or for setting the tile? Or both? Just making sure I'm on the same page
DG
Remodeler
dgbldr is offline   Reply With Quote
Old 01-22-2018, 06:35 AM   #11
tilemanct
Tile & Stone
Solved that dilemma years ago. Changed from Schluter to other manufacturers. Found products that exceed them in many ways.
CTEF Certified Installer
Old 01-22-2018, 08:34 AM   #12
MAPEI - Technical Service
Company Representative
Glad to see some MAPEI products got an honorable mention here. Our Kerabond T meets Schluter's requirement for a non-modified mortar and is specifically designed to be used with uncoupling membranes and large format tiles. If you haven't tried it, give it a shot. For the 'tile in the same day' discussion I agree with Ultraflex RS or if you're going over it with a large format tile, Ultraflex LFT Rapid is a relative newcomer that's worth a look.
http://www.mapei.com/US-EN/
Old 01-22-2018, 08:50 AM   #13
Lazarus
Lazarus's Avatar
Dan....Recently, I've been using Kerabond for Kerdi and it works great. My local Dal dropped the 317 and picked up Mapai. It was at their recommendation that I tried the Kerabond.
Laz...
Old 01-22-2018, 07:41 PM   #14
Originally Posted by Shady at Best
...I am doing a job where I am installing ditra on plywood. Looks like ditra set is good for that application.
No, that's a bad idea. Using an unmodified over plywood is a bad idea. Unless you want it loosing it's bond sometime in the first 7 years. This isn't Schulter just talking, it's the whole industry. And primer wouldn't alter that. Use a mortar rated for plywood and you're golden.
Old 01-22-2018, 09:08 PM   #15
Shady at Best
Tyrone shoelaces
Originally Posted by Tool Guy - Kg View Post
No, that's a bad idea. Using an unmodified over plywood is a bad idea. .
I know this. I have no idea why i said it. Would help if i proofread once in awhile.
Pretty much both.
Just looking for suggestions and better ways to do things.
I Have been spoiled lately by using ardex x77. It has got me wanting to get away from customs versabond. Although i have no real beef with versabond. I would use x77 all the time if i got the same coverage out of it.
I worry about the thinset I use when doing kerdi seams. I have used thinsets where there was no resistance when peeling up kerdi band after 2 days of drying. I Have also had schluters all set fail to hold on to usg durock membrane after 2 days of drying.
I have also seen thinset pull the fleece off the kerdi after 2 days.
So basically looking for a better, easier, ways. I haven't used laticrete thinset in years. Maybe i will give there stuff a shot.
Travis
Thinset too thick for Kerdi?? Ditra Set?? stevepwlb Tile Forum/Advice Board 3 05-31-2014 12:42 PM
Best thinset for Kerdi and Ditra? handigirl Tile Forum/Advice Board 23 01-21-2010 07:45 PM
Thinset over KERDI............er, um....Ditra Hammy Professionals' Hangout 30 09-02-2009 07:29 AM
What is your favorite thinset for ditra? Racer X Tile Forum/Advice Board 32 04-21-2009 07:35 AM
Best thinset over Kerdi and Ditra tiffanp Tile Forum/Advice Board 8 08-30-2007 09:42 PM
