Old 01-19-2018, 11:04 AM   #1
wopachop
Why is this grout black along the corners only?
Hello everyone learned a ton from this forum over the years. Im stumped on what is causing grout to turn black. At first i thought the weep holes were plugged, and water under the tiles is darkening the grout.
Then i thought its just mildew and needs to be cleaned.
I cleaned with Miracle Heavy Duty acid cleaner. Not a single spec of black color comes off. The scrub pad i used did not pick up any black color either.
When i get the grout wet, it does not change color.
Why is the black color just along the corner edge? Shower is located in southern california where hot mop shower pans are popular. Can it be tar related? Black magic maybe? Mildew under a layer of grout sealer?
Thanks for any advice on the cause and the correct repair.
Tony
wopachop is offline   Reply With Quote
Old 01-19-2018, 11:08 AM   #2
Tony,
Your shower pan is holding more water than it should, not letting it dry as normal.
1- Do you have any idea if the hot mop was sloped towards the drain?
2- Do you have any idea if there is pea gravel (or similar) around the drain?
3- I'd be looking at removing the shower floor and having it properly re-set with the right drypack mixture, gravel around the drain, and caulking at the changes of plane.
4- Is the curb showing any signs of puffing? expansion? cracked joints & tiles not aligned?
Old 01-19-2018, 11:29 AM   #3
wopachop
Unfortunately we know nothing about the construction of the shower. Can i pop off the shower drain cover and possibly get some clues?
I can look closer at the curb next time over there. While trying to clean i did not discover any cracks in the grout, or any tiles that appear to be coming loose.
If its water under the tiles then why is the black color only along the edges? Wouldnt the entire floor show signs of dark grout or mildew?
Tony
Old 01-19-2018, 12:05 PM   #4
Yes there is water under the tiles, sammiched between the tiles and the vinyl liner is a 2 inch thick layer of drypack. (cement)
Old 02-16-2018, 10:30 AM   #5
nesc39
So your saying he has 2.5 of pan water that is only affecting the highest part of his floor?
Repid
nesc39 is offline   Reply With Quote
Old 02-16-2018, 07:21 PM   #6
lati_cz
michal
isn't is tar?
Michal
lati_cz is offline   Reply With Quote
Old 02-18-2018, 11:28 AM   #7
It's hard to say, without knowing more about the installation, all we can do is guess. Mold is what we usually see but I don't think it's mold this time. If it were mold, the cleaners you used would have at least removed some of the black. I believe it's the oils in the tar soaking into the grout. I've worked around hot mop pans before and have never seen this happen, maybe someone else has.
If the studs aren't notched to allow the pan to be recessed back, the pan will stick out almost as much as the cement board. I have tore out showers where the installer stuck the tiles right to the pan liner along the bottom. My guess is that's what he did, stuck the tiles to the hot mop along the bottom.
If that's the case, the grout would need to be cut out and replaced in the black areas. Care would have to be taken not to cut too deep and cut into the pan.
Old 02-19-2018, 11:16 AM   #8
As to the water affecting only the highest part of the floor, that happens to be the last place to dry out in any shower no matter how it's built. . . unless the shower is towel dried after use.
just installed black granite tiles and black grout is white in some areas. Jmarie Cleaning, Restoration and Sealing 6 07-19-2011 06:03 PM
30 yr old black slate with dirty black grout cbell50 Cleaning, Restoration and Sealing 4 11-22-2009 07:25 PM
Black grout is grey, not black.... Duane903 Tile Forum/Advice Board 24 04-28-2008 08:53 PM
Black Slate and Black Grout question Chloe B Cleaning, Restoration and Sealing 3 02-25-2006 07:18 AM
Grout Question-unglazed white 1" hexagon tile w/black grout jburrows500 Tile Forum/Advice Board 6 12-05-2005 09:32 PM
