Old 01-18-2018, 06:02 AM   #1
Big Taco
Marble re grout question
hey guys, forgive me if this has been addressed already. I have a bathroom floor that has 1" hexagon Carrera marble. It was originally grouted with sanded grout. The contractor sealed the tile and grout while the grout was dirty. It was then gone over with non sanded, which was my mistake. Grouts don't match up. Is there anything I can use to remove the non sanded grout and some of the original grout, so I can re grout without replacing the floor? I've tried grout haze remover, nano scrub, etc. Didn't do anything.
What will happen if I use sulfamic acid? It is polished.
Thanks in advance.
Jeff
Big Taco is offline   Reply With Quote
Old 01-18-2018, 09:43 AM   #2
Jeff,
Keep any and all acids away from the marble as they will permanently etch the marble making it dull.
The only way to remove the grout is to scrape /grind it from between the tiles.
You'll need something like a carbide dental drill and tons of patience.
I'd start by emptying the cuss jar.
Old 03-06-2018, 07:34 AM   #3
jellybean
Vibrating Dremel type tool is good for removing grout
A multimax with some carbide grout blades is what you want for grout removal
Steve
jellybean is offline   Reply With Quote
Old 03-06-2018, 07:36 AM   #4
jellybean
rather than removing the grout
How about using Aquamix grout colorant? It's an epoxy based coating that's tougher than the grout it covers. I used it in my shower 17 yrs ago and it's still amazingly new looking - plus it doesn't absorb water, so no mildew issues!
Steve
Old 03-15-2018, 10:57 AM   #5
magicman94
Dremel
I would use a Dremel with a round blade attachment. You just have to be sure you don't score the stone, so you have to keep it straight.
Sean
magicman94 is offline   Reply With Quote
Polished marble and epoxy grout question chriswall Tile Forum/Advice Board 7 04-21-2017 01:08 PM
circle marble tile grout question HeatherG Tile Forum/Advice Board 14 02-02-2011 08:35 AM
botticino tumbled marble grout question tunafish Tile Forum/Advice Board 6 03-02-2006 11:15 AM
Question RE using Teflon-treated grout with marble: missmarble Tile Forum/Advice Board 3 08-17-2005 05:38 AM
Question regarding cleaning grout and marble in shower LoriE Cleaning, Restoration and Sealing 2 04-07-2005 07:16 AM
