Old 01-16-2018, 03:24 PM   #1
Lazarus
Lazarus's Avatar
Grout Width on "Wood Look" Tiles
My first job with this type of tile was over 12 years ago. At that time, this stuff was ten bucks a sq. ft. plus. Lady wanted it simply butted up...just like wood. Not knowing any better, I obliged. Tile was awesome and it worked with virtually ZERO lippage.
Fast forward to today. I generally go about 1/8" unless the bowing requires otherwise.
Recent job...three bedrooms and about 500 ft. to tie into existing tile which had them butted tight...but with grout. OK, I butted them and grouted with Fusion Pro. With the beveled edges, it still appeared to have 1/8" grout lines and the HO is VERY happy. Never woulda' thunk it, but there is no sun exposure and I'm not too concerned about tenting.
I guess with the right slab and the right tile, this is possible/acceptable.
Laz...
“Everything in excess! To enjoy the flavor of life, take big bites. Moderation is for monks.”
Old 01-16-2018, 03:48 PM   #2
Just In Tile LLC
Just In Tile LLC's Avatar
I'll do 1/8" most of the time as well, unless the tile has a beveled edge and 1/8" spacers push it to more like 3/16"-1/4" showing. For that I'll pull out the 1/16th" spacers.
If tile is 3' or more.... the jobs get no lip spacers attached to them.
Would be cool to get charts or ratios on failures when conditions are similar.
1 out of 50 jobs tent when butted... or 1 out of 100 or whatever. But I guess some of us would reverse that information and use it to.......gamble. not me of course :X
Justin
Old 01-16-2018, 04:32 PM   #3
Of course other things come into play when talking about tenting. The type thinset used and how clean the slab was when the tile was installed, etc. All of us have seen tiles installed over a layer of texture and paint that was hardly bonded. Won't take much for that floor to come loose or tent.
Old 01-19-2018, 05:07 PM   #4
All the plank tile I've done in the Tampa areas are tight as possible with consideration taken into for bowing,
edge straightness, sizing quality, rectified or cushioned edge and slab flatness. Also grout color is key to making it look great.
I have done a few with 1/4 and 3/16 grout joints per box suggestion and wasn't a fan.
That and also the 1/3rd offset or 50/50 patterns aren't my thing for installing plank tile.
1/8" cushioned edge
1/16" to 1/8" rectified.
Old 01-19-2018, 05:32 PM   #5
Just In Tile LLC
Man that looks good!
Justin
Old 01-19-2018, 05:34 PM   #6
Thanks. I like matching the grout color shade and going a little darker.
Old 01-19-2018, 09:19 PM   #7
Karls tile Inc
Tile and stone contractor Tile setter
Looking good for sure! I usually install wood plank at 2MM grout joint.
Karl
Karlstile.com
Karls tile Inc is offline   Reply With Quote
Old 01-21-2018, 03:22 PM   #8
Cripes! That 3rd picture of Brian's looks outrageous! Even if the rest of the tile in the house looked horrible, that little section would make up for it. I mean....even if the rest of those planks were installed with nails, it would still be worth it.
Old 01-22-2018, 06:50 AM   #9
tilemanct
Tile & Stone
The bottom pic. Who makes that tile?
CTEF Certified Installer
Old 01-22-2018, 03:21 PM   #10
Its the Lowes "Style Selections" (made by Stone Peak for Lowes) 8x48 Natural Timer Ash
Old 01-22-2018, 03:28 PM   #11
It looks good all over the place
Old 01-22-2018, 03:41 PM   #12
Lazarus
Lazarus's Avatar
VERY nice work, Brian!
Laz...
Old 01-22-2018, 06:38 PM   #13
Brian, who makes post #11 tile?
Old 01-22-2018, 10:49 PM   #14
Lowes "Style Selections" 8x48 Natural Timer Cinnamon
Old 01-23-2018, 12:34 AM   #15
Now I’m tempted to get some, slightly back-bevel all four sides so that I’ve got a reverse trapezoid tile-thing going so that the top edges can practically touch each other, and get the grout lines down to 1/64”.
...says Taco Guy - Kg.
Which grout coloring sealer do you recommend? "Grout Renew","Grout Refresh", or ? Fun2Learn Cleaning, Restoration and Sealing 1 02-22-2016 07:25 AM
Grout width per " standard in design" danielskitchenbath Professionals' Hangout 4 03-18-2008 06:24 PM
1" Hexagon Tiles "Re" Grout? jennat Tile Forum/Advice Board 1 06-30-2007 08:54 PM
is there a "standard" width for tub surround? plus more donnas62@aol.com Tile Forum/Advice Board 8 02-01-2007 12:38 PM
Granite tiles, first time with unsanded grout should it be "smooth"? dominogold Tile Forum/Advice Board 6 05-10-2006 01:03 AM
