Old 01-03-2018, 11:20 AM   #1
Chester Kaup
How to layout tiles?
I am going to be tiling a hall and three rooms that touch the hall. It is a long hall that starts off the entryway that is not tiled. I am have a couple of thoughts of how to layout the tile but welcome ideas.
1. Align the tile down the center of the hallway and then tile into each room. The tile of course will not be centered in the rooms
2. Tile each room centered and then run it into the hallway. This will probably make nothing line up in each doorway.
Chester
Chester Kaup is offline   Reply With Quote
Old 01-03-2018, 11:38 AM   #2
jlbos83
Really Cool Weekend Warrior
You could use a relatively narrow accent tile in each doorway, and get the best of both worlds.
I think it is important to have the hallway makes sense. You will have furniture and other things breaking up the look and hiding the walls in the rooms. Spend some time thinking about it.
Jeff
It's a DRY heat!
jlbos83 is offline   Reply With Quote
Old 01-03-2018, 06:54 PM   #3
I would center the hall for equal cuts along each side and let the tile flow into the rooms. Like Jeff said, the cuts in the rooms won't be as critical.
Old 01-03-2018, 07:14 PM   #4
I, too, would make the hallway a priority.
Need suggestions for layout of 9“x12” tiles in my shower? joe979xx Tile Forum/Advice Board 3 04-18-2016 07:11 PM
Wood Look Tile Layout - 3 different sized tiles Upticked Tile Forum/Advice Board 6 01-29-2016 09:17 AM
Pattern layout and the cut tiles JPeter Tile Forum/Advice Board 2 04-26-2010 01:54 PM
layout sequence for different tiles on one floor. krisdw Tile Forum/Advice Board 2 10-05-2005 04:24 PM
Wrapping Tiles in a Layout DreamQueen Tile Forum/Advice Board 9 11-03-2004 09:09 PM
