Old 01-01-2018, 08:47 PM   #1
GoRoos
Minimum size for leveling systems?
Hey there - lurker/reader here, but first post - so thanks for all the learning you've provided already
I'm pretty-darn newbie to laying tile where looks matter. (I worked for a non-profit over summers and weekends during college, and we laid donated tile when we built shower houses and stuff at a summer camp...but looks never mattered.) I'm DIY'ing a bathroom remodel now - and looks matter a bit more when it's your own house . I've done the reno, installed a new tub, and almost finished installing the new drywall and hardiebacker - redgard going up over that before I get to tiling.
I've never used a tile leveling system before - but certainly want the best I can do. Seems like these things will result in a much better job.
I'm likely doing a the shower walls with 3x5 subway tiles and the floors with larger-format (probably 4x24).
Most everywhere I see the leveling systems advertised, they hint that they're for "large format" tiles.
Is that meant to imply that there's some minimum size below which they aren't useful and/or can't be used? If so, what's that minimum size? Are 3x5 subways too small?
Thanks again for everything so far - and for dealing with the many questions I'm bound to ask now that I broke down and created an account
Jay
GoRoos is online now   Reply With Quote
Old 01-01-2018, 08:52 PM   #2
rmckee84
You wont be able to use them with the 3x5 nor would you need to. You could use them with the 4x24 if needed.
Ryan McKee
Minimum size Grout Line? jlrehmann Tile Forum/Advice Board 7 12-10-2014 06:00 PM
Minimum Size for a Piece of Ditra? Blumba Tile Forum/Advice Board 4 11-23-2009 02:39 AM
Minimum shower size Partsman Tile Forum/Advice Board 5 03-30-2008 11:02 AM
Minimum tile size with Ditra trafferty Tile Forum/Advice Board 4 08-10-2004 06:48 PM
Minimum Size of Grout Joint Ron Teti Tile Forum/Advice Board 1 07-31-2002 06:09 AM
