Old 12-31-2017, 10:48 PM   #1
adamwsmith1980
Shower Pan on Concrete Slab with Concrete Curb
Hey Everyone!
New to the forum. Used to do construction back in the day and have experience in just about everything. Times and products have changed since I have been in the field (15 years) so I'd love your help and expertise.
I bought a house with an unfinished basement last summer and am just about ready to start the bathroom. I've not done a shower pan over an existing slab and haven't done a concrete or brick curb. Everything I've read online either points to a traditional liner over the concrete curb with diamond mesh then mortar over that, or kerdi over everything.
Here is my goal, do this the cheapest (cost wise not quality) way possible. My buddy in Seattle who does kitchen and bath remodels only uses Wedi, but I am on a budget. What is the cheapest system to use? I believe I need a modified thinset to get my pan to adhere.
Thanks in advance and Happy New Year!
Adam
Adam
adamwsmith1980 is offline   Reply With Quote
Old 12-31-2017, 11:05 PM   #2
Welcome to the forum, Adam.
Cheapest route is the traditional PVC liner on the floor, 6-mil plastic on the studs, and cement board on the walls. In the Liberry there are complete instructions, and you can ask any questions you have right here on this thread.
Not sure what you're referring to here.
Old 01-01-2018, 02:40 PM   #3
adamwsmith1980
Thanks Kman! I mean for my preslop material to bond to my slab won't I need a modified thinset of some kind? I read somewhere that you want the drypack to be able to adhere to the slab.
Found some useful info in the Liberry. So pan liner then cement board on the walls. I've never used redgard. Is that what you'd recommend over the cement board?
Adam
Old 01-01-2018, 03:38 PM   #4
Hi Adam. For a traditional pan liner installation you'll need a mud preslope under the pan liner. The preslope will need to be bonded to your slab and then once it sets up, the liner is laid in place but not bonded to the preslope. The only job of the preslope is to give the liner slope to the drain. The liner is clamped into the 3 pc clamping drain and then a second mud bed goes on top of the pan liner.
But, yes, the mud preslope is bonded to the slab with modified thinset.
Old 01-01-2018, 10:08 PM   #5
adamwsmith1980
Thanks Davy! So just put a skim coat down and that's it?
Adam
Old 01-01-2018, 10:26 PM   #6
A small-notch trowel works well. I use a 1/4" notch.
Concrete floor and concrete curb jeffersonm Tile Forum/Advice Board 3 07-28-2017 06:22 PM
shower curb out of concrete? mccannconst Tile Forum/Advice Board 6 04-12-2013 06:03 PM
Using a solid concrete shower curb? joverdorff Tile Forum/Advice Board 2 12-31-2012 09:35 PM
Concrete shower pan on Concrete slab. Chucker Tile Forum/Advice Board 4 04-14-2007 01:32 PM
Shower curb creation over concrete slab ranchopedro Tile Forum/Advice Board 1 09-12-2006 11:24 AM
