Old 01-02-2018, 07:33 AM   #31
You got a Lowe's nearby? Either Mapei or Tec has a floor patch that would probably work. One of them should be available at your local store.
I think the maximum you can build them up is 1/2", but you can shim the floor the rest of the way as needed. That's not a standard practice, but your project is a little off the blueprint anyway.
Old 01-02-2018, 09:40 AM   #32
klepp0906
yea a 1/2" may be enough anyhow. A little mush to let it work its way down im ok with. I just dont want someon stepping there to potentially rip planks apart or crack them or something crazy. on the thinner stuff the tongue/joints doesnt seem as robust (naturally considering its meant for flat flooring)
I am literally 2 minutes from a lowes so thats great. What would/should i use to shim/what would be easiest? Would any material work or is there something that would be more ideal?
I hate "hacking" but the 50's homebuilders gave me no choice! Ugh ive fought this house tooth n nail every step of the way but the slab/adhesive/grade down there takes the cake.
as always, sincerely - thanks for the replies guys. This is a tad above my pay grade and it needed to be done like yesterday :P
klepp0906 is offline   Reply With Quote
Old 01-02-2018, 09:55 AM   #33
klepp0906
also whats the MO on the drain? cut a peice of pvc to extend it up closer to level and use the patch around/against it?
Old 01-02-2018, 11:01 AM   #34
Yes, that's what I had in mind for the drain.
You can use layers of roofing felt for shimming.
Old 01-02-2018, 11:42 AM   #35
klepp0906
good idea on the felt. Think i have some left over in the garage too.
here is the stuff im thinking about using which may all but omit the need to shim too.
says up to 1 1/2" which is way more than i need.
https://www.lowes.com/pd/TEC-Skill-S...Patch/50064113
look/sound feasable?
thanks once again.
Advice on cutback djaco Tile Forum/Advice Board 4 04-29-2015 06:55 PM
Tiling over black cutback mastic Rick Conner Tile Forum/Advice Board 14 04-25-2012 08:08 PM
Mastic cutback adhesive / latex paint / vinyl tiles house_trained Tile Forum/Advice Board 4 10-07-2011 11:41 AM
Black Cutback Mastic ppmnc Tile Forum/Advice Board 4 05-25-2010 05:47 PM
A solution for cutback black mastic on a large floor area…will it work? swingthought Tile Forum/Advice Board 22 01-03-2010 10:33 PM
