Old 12-30-2017, 02:22 PM   #1
Steph13
Making Steps
Continuing my remodel, we are now working on the kithen which rises up 2 steps from the sunken living room. (Slab 1 story house in North texas). My contractor is cutting 24x24 porcelain tiles and beveling the edges fitting them together to form steps. The edges are already chipping. Is this the best way to tile the steps?
The contractor is a CTI.
Steph
Steph13 is offline   Reply With Quote
Old 12-30-2017, 05:04 PM   #2
jwmezzanotte
jwmezzanotte's Avatar
That chipping happen from cutting the miters on the tile or did it happen after installed? Just curious.
I've done some similar stairs in the past, a mitered edge like that is pretty easily chipped. Even after grout.
I also did a big set of stairs that had a square tile edge (rough strip of tile for grip)
Even that one has chipping now. It is in a hotel lobby though, so I know people aren't gentle on it. Dragging luggage up and down etc
Old 12-30-2017, 05:07 PM   #3
jwmezzanotte
How else would you like it finished?
There are stair edge trims etc, but it would take away from that clean one piece look.
Old 12-30-2017, 05:21 PM   #4
I've beveled corners on walls like that but not on steps, just for that reason. That soft marble can't support much weight before breaking off. I would have run the square edge out and polished it or bullnosed the edge and polished it.
Old 12-30-2017, 08:17 PM   #5
Steph13
Porcelain tile
The tile is porcelain masquerading as calacatta. I don't how to make steps so not sure how to make them sturdy. But I want something durable, I thought porcelain was a practical choice.
The contractor just finished grouting the steps Friday at 2pm. No one walked on them Until 7 pm.
Steph
Old 01-01-2018, 10:07 PM   #6
Steph13
Sanding Beveled/Mitered Steps
Will sanding the edges of the steps help keep them from chipping?
Steph
Old 01-02-2018, 08:17 AM   #7
The reason I mentioned bullnosing and sanding is because I thought you had marble. Porcelain will chip less than marble but it all depends on how much traffic the steps get. Square edged tiles can be bullnosed, kind of late for that now since they beveled them. Surely these tiles have a 3x12 BN available, I would have pushed for those.
I can't say if sanding will help. I guess you can try it.
Old 01-02-2018, 12:55 PM   #8
Steph13
Steps
This porcelain did not bullnose well when the contractor tried it for the tub surround. He ended up sanding, painting w appliance paint, then caulking.
I had purchased some of the polished daltile bullnose, but the contractor didn't like it, (I agreed) and the wrong amount was ordered so we were short. But where we're are now is about matte flooring.
Thanks for responding!
Steph
Old 01-02-2018, 01:20 PM   #9
Steph13
Steps
Steph
Old 01-02-2018, 04:31 PM   #10
rmckee84
Did he use an actual machine designed for making bullnose or just a grinder and router bit for bullnose? You may have better luck taking it somewhere that can machine the bullnose.
Ryan McKee
Old 01-02-2018, 07:18 PM   #11
Look up American Bullnose Company, they have a location in Dallas along with many other cities across the country. I believe all they do is bullnose. They BN the edge and fire them. They use your tiles so there is never a shading problem.
Tiling steps earlyretirement Tile Forum/Advice Board 6 05-10-2008 10:52 AM
Making your own shower steps johnalaimony@yahoo.com Professionals' Hangout 26 01-31-2008 11:46 AM
Steps to tiling a flight of steps??? dave on his knees Professionals' Hangout 10 04-25-2007 09:22 AM
Steps down... Furthur Tile Forum/Advice Board 15 06-29-2005 06:00 PM
Help with outside Steps Iowaboy Tile Forum/Advice Board 6 06-25-2005 06:05 PM
