Old 12-29-2017, 12:22 PM   #1
Evanston
Removing & Replacing tile over Ditra heat
Seeking help from the true professionals on this board.
My now-departed installer put a couple of tiles (4x4 tumbled marble) down that have, shall we say, more than rounded - i.e. chipped - corners, and the appearance bothers me, particularly since we had plenty of extra tile. They’ve been down about a week. It took him two days to do a floor about 3’ by 8’, tiles on the diagonal. Not including the Ditra install. Or the self-leveler. Or the cable layout, which I did for him.
We have not yet grouted.
For reasons not worth getting into here, I will not be asking him to return to attempt a fix. I’m actually going to be finishing the job myself.
What is the likelihood of being able to replace one or two tiles without creating bigger problems? I have an angle grinder, chisels, scrapers, and other tools (a deceased relative was in the trade) and certain amount of patience. I have a photo of where the heat cables were run. I have some extra Ditra, but I don’t know that cutting it out is an option.
Should I make my peace with floor and move on, or is there a possibility of fixing this?
Thanks in advance,
Alex
Alex
Evanston is offline   Reply With Quote
Old 12-29-2017, 01:48 PM   #2
Do you know what thinset mortar was used to set them?
You'll want to break them up into smaller pieces to remove them. A nail set works best for that.
Old 12-29-2017, 04:38 PM   #3
Evanston
He used Schluter All-Set
Alex
Old 12-29-2017, 07:32 PM   #4
Probably won't be easy after a week, but the sooner you start, the better. Just don't get too aggressive. Start small and work your way up to the minimum amount of force it takes to break the tile up.
Old 12-29-2017, 09:22 PM   #5
Evanston
Thanks; I'm going to look at it in the morning and decide how brave I am. Appreciate the suggestion of using a nail set.
Alex
Old 12-29-2017, 09:45 PM   #6
I've used the nail set method with success.
And I've used an angle grinder cutting deep scores into the tile with success. With cutting scores every fraction of an inch, it give you the opportunity to use a large flat-headed screw driver to pry the little sections apart. I try to use a twisting motion much more than a traditional up/down prying motion.
Replacing kitchen floor tile w/out removing cabinets JimmyH Tile Forum/Advice Board 10 12-30-2009 01:47 PM
replacing broken tile over radiant heat cables Buildingmy1sthouse Tile Forum/Advice Board 4 04-09-2009 06:17 PM
Removing vinyl, replacing with ceramic tile Greg Thomas Tile Forum/Advice Board 2 02-23-2008 12:02 PM
Removing and replacing granite tile set with medium set MaikeruM Tile Forum/Advice Board 1 05-26-2005 09:20 AM
Removing and replacing small area of mosaic tile jas_il Tile Forum/Advice Board 2 11-13-2003 06:19 PM
