Old 12-28-2017, 01:42 PM   #1
Arizoner
Unknown Saltillo sealer. Strip anyways?
Hi, I moved in to an existing house, and do not know the history of the tile. I'd like to seal it for preventative measure. Since I don't know if it's been sealed in the past, and have no issues with how it looks right now, can I simply use a sealer as is right now, or do I need to use a stripper, just in case there is a sealer on it now. Approx 1000sqft, Exterior tile, Phoenix area, 6 hours sun/day, gets some water from grass area. Thanks!
Arizoner
Arizoner is offline   Reply With Quote
Old 12-28-2017, 04:20 PM   #2
I'd strip that, then seal it. The manufacturer of your sealer will probably tell you the same thing.
Old 12-30-2017, 01:20 AM   #3
claycarson
Commercial Cleaning and Maintenance
Pretty stuff! We don't see it as much in New England, but I saw more of it when I visited your beautiful state of Arizona.
I'd agree with Kman. Strip cuz it makes the surface better to receive new sealer. Just don't use heavy abrasive black nylon pads like they use to strip vinyl floors. Saltillo is fragile and heavy abrasion can break the outer crust of the tile.
I'm less sure which brand sealer. I like acrylics in general for Saltillo. They sell some durable solvent based acrylics that are flammable but OK to use outdoors. Had to grind one off a concrete floor once and it was murder to get off, leading me to think it's pretty darn durable. Had a decent shine, too. I bleeve it was a Brickform product, could look it up if you're interested.
Sent from my SM-G920T using Tapatalk
Clay
www.tileboston.com
claycarson is offline   Reply With Quote
Old 01-09-2018, 09:56 AM   #4
Hi Arizonar,
I used to live in Pheonix, and I did a fair amount of Saltillo work back in the day. You don't have real Saltillo, which is very rustic and irregular in shape, color and texture. I think your tile might have been made in the states.
In any case, it's similar to Saltillo tile, and outdoors it can be either sealed with a penetrating sealer or left as is. If you're going to seal it I recommend Thompson's Water Seal or similar. Do not use a topical coating on it, and I wouldn't worry about stripping it.
stripping unknown sealer Traci Lee Cleaning, Restoration and Sealing 11 03-26-2011 12:26 AM
Slate Shower w/ Unknown Sealer nivedl Cleaning, Restoration and Sealing 5 12-02-2009 05:34 PM
Strip Saltillo w/ Colored Grout chado Cleaning, Restoration and Sealing 3 10-11-2006 10:17 PM
Saltillo tiled floor (to strip or not to strip) chrisusvi Cleaning, Restoration and Sealing 4 11-23-2005 06:52 AM
Saltillo Tile strip and resealing dennis_wozniak@msn.com Cleaning, Restoration and Sealing 2 05-01-2005 06:27 AM
