Old 12-15-2017, 07:14 PM   #1
edbianc
Silicone stain on granite
About 10 years ago we had granite counter tops and 4" high granite back splash installed in our home. I decided to remove the granite back splash and will be installing a full length back splash of a mosaic. My problem is when the granite back splash was removed a stain line exists where the sealant used in the joint between the back splash and the counter top. Photos attached.
I have tried poultices of baking soda and acetone, baking soda and dish washing soap, and rubbing alcohol. Nothing seems to lessen this stain. Can anyone offer a solution? Thanks!
Ed
edbianc is offline   Reply With Quote
Old 12-16-2017, 10:35 AM   #2
Hi Ed, Welcome aboard.
Are you sure all the silicone has been removed? You can't get at the stain otherwise.
Old 12-16-2017, 02:13 PM   #3
edbianc
Hi John, thanks for responding. I believe I have gotten all the silicon off that will come off with a straight razor and a scraper. (Is there something else I should try?) It does not feel like there is any silicon left nor can I see any residue.
I just put on a poultice of flour and hydrogen peroxide (30%) and will leave it on overnight to see if that will do anything.
Ed
Old 12-17-2017, 11:17 AM   #4
edbianc
Well the peroxide mix did not seem to do anything to my stain. Does anyone have a suggestion?
I will reapply this mix again in the hope that multiple applications might help.
Ed
Old 12-17-2017, 11:59 AM   #5
wwhitney
There are products marketed as "silicone remover" that would, I presume, chemically attack the silicone. Not having any experience with them, I would say there may be a risk that the silicone remover itself might leave a stain, or possibly be absorbed by the granite and interfere with future use of silicone or other caulk. You could test one of them in a small area, maybe taping off behind the silicone stain where you will be caulking in the future at the tile/counter top interface.
Or perhaps you could find a local granite fabricator that has some experience with this issue and would know how to handle it?
Cheers, Wayne
Wayne
Old 12-17-2017, 04:40 PM   #6
The only product that comes to mind is Dicone9 from a company called Prosoco. But I've not dealt with a sub-surface stain in granite like that. I'd call their customer service. (800) 255-4255
Old 12-17-2017, 08:52 PM   #7
edbianc
I have heard of Divine, but it is very expensive (like $100 gal) and I don't know anyone who has used it. However I will call them to set what they say.
Thanks.
Ed
Old 12-17-2017, 10:29 PM   #8
lati_cz
michal
can't you add layer of drywall?
Michal
lati_cz is offline   Reply With Quote
Old 12-17-2017, 10:55 PM   #9
Topspin
SchluterUgrad
Topspin's Avatar
If it won’t come off might consider some kind of enhancer to make the balance of the granite match the silicone appearance.
Old 12-18-2017, 07:04 AM   #10
edbianc
- lati_cz, The original granite back splash was 1.25" thick, so adding drywall would require expanding the wall at least 1.5", which is a lot. But it was a good out of the box suggestion!
-Topspin, I had thought about this solution also and may be the solution of last resort. What kind of "enhancer" would one use to mute the existing stripe effect?
Ed
Old 12-18-2017, 09:47 AM   #11
wwhitney
Another option would be to use a cove base tile, instead of padding out the whole wall.
A google or amazon search for "silicone remover" comes up with a number of products besides the Dicone9. I have no idea if they work.
Cheers, Wayne
Wayne
Old 12-18-2017, 08:46 PM   #12
edbianc
I am getting a free sample of Dicone NC9 to try but it will have to wait until after the holidays.
Ed
Old 12-18-2017, 10:33 PM   #13
Is it coming from Prosoco or a local dealer?
Always remember the golden rule when it comes to restoration stuff. TEST in a hidden or inconspicuous spot before committing to the whole thing.
Old 12-19-2017, 07:20 AM   #14
edbianc
I had the local Sherwin Williams store order it from Prosoco, since they carry their products.
Ed
Old 12-19-2017, 07:36 PM   #15
Cool. Prosoco is one of those companies that I really like because they make really good products. Glad SW is getting you a sample.
Silicone Stain on Granite Akloman Cleaning, Restoration and Sealing 8 09-03-2014 06:36 PM
How to clean silicone from granite Mwalt Cleaning, Restoration and Sealing 6 08-21-2008 10:53 PM
removing silicone from granite -Christopher Cleaning, Restoration and Sealing 6 03-05-2008 02:11 PM
Removing Stain caused by Faulty Silicone on Granite HiLoGraniteGuy Cleaning, Restoration and Sealing 2 04-28-2007 10:40 AM
mount granite with silicone?? teehee Tile Forum/Advice Board 8 10-02-2006 05:38 PM
