Old 12-11-2017, 02:19 PM   #1
lati_cz
michal
dimmer question
Friend of mine asked me to replace existing switch with dimmer. The switch controls 4 low voltage lights and 2 incandescent fixtures.
Is there dimmer that can handle combination of low voltage and standard bulbs? Thank you Michal
Michal
lati_cz is offline   Reply With Quote
Old 12-11-2017, 07:49 PM   #2
Never seen one. I thought they were pretty exclusive to each other.
If you tied the switch legs from both fixtures to a switch, when it's turned on you'd have 120 volts going to your low voltage fixtures as well.
I think you'll need two switches.
Old 12-11-2017, 08:13 PM   #3
I've never tried it, Michal, but I suppose it could work. You'd be reducing the input to your 120v bulbs and to the transformer that's operating your low voltage lights. I don't see a downside to trying it and then we'll all know whether it works or not.
Old 12-11-2017, 08:29 PM   #4
Those Lutron CFL / LED dimmers may work
Old 12-12-2017, 08:31 PM   #5
lati_cz
michal
Thanks guys, I sent question to Lutron, they said no....
Michal
Old 12-12-2017, 08:40 PM   #6
They would know best
Old 12-14-2017, 07:04 AM   #7
Gozo
It depends of the type of low voltage fixtures. Most of those I have are based on switching supplies. They dim kind of of bit, then to about halfway and then off. More so with LED lamps. I wanted dimmable spots in the bedroom so I could lower them down when reading real books before sleeping. (Yup, I still read paper stuff sometimes.)
Anyway, the low voltage bulbs on that line are based on a magnetic ballast. The fixtures were bigger, heavier, and cost more, but dim smoothly from full to a glimmer as does the regular incandescent lamp on that line. Iím using Lutron dimmer rated for magnetic and incandescent. Dimming LED and CFL Iíve found to always be less than satisfactory.
Jeff
Newbie Deflecto question and subfloor question. gonemob Tile Forum/Advice Board 2 09-19-2012 02:12 PM
Tiling a wall; curb question; shelf question Todd brown Tile Forum/Advice Board 34 04-08-2010 06:03 AM
Kerdi Shower Pan question and Tub Apron question jhilb Tile Forum/Advice Board 6 03-07-2010 01:23 PM
marble question and shower smell question Pamela K Tile Forum/Advice Board 7 10-02-2005 02:44 PM
Grout question and Backsplash EDGING question BarbFreda Tile Forum/Advice Board 15 05-24-2003 04:16 PM
