Old 12-07-2017, 12:03 PM   #1
eartha5
bunch-up/build-up of kerdi band in places
Hi folks,
I am waterproofing and tiling a shower with Shluter materials for the first time and everything has gone swimmingly, except for a few corners around the custom curb that I've made out of kerdi-board.
At one spot, I had to fold a schluter outer corner up in a way where I ended up having three layers of the band material tightly folded up together. So with thinset in there, even with extreme care trying to flatten that mess out, I still have probably 3/16 difference in the outside of that folded and set material and the kerdi-board behind it.
I am wondering if this is going to be a problem to deal with when I put down the tile. I am using 12x24 tiles and a 1/2 in notch trowel, so I suspect I'll have at least about 1/4 inch of mortar underneath the tiles. So theoretically my 3/16 inch 'bump' of kerdiband will get absorbed within that bed of thinset, right?
It feels like it won't be an issue, but considering how much care you try to take in getting everything flat before tiling, I am a little worried about it.
Anyone have advice? I can't really do the corner any other way that I can think of where Shluter's specs with regard to overlap of the band would be met, and ensure a water tight pan.
Vic
eartha5 is offline   Reply With Quote
Old 12-07-2017, 02:58 PM   #2
Lazarus
Lazarus's Avatar
Vic....With that size tile, I would think that you should be able to build out the tiles to where they would blend well. Much has to do with how plumb the walls are. If they're a bit "out," that might work to your advantage.
Laz...
Old 12-07-2017, 06:42 PM   #3
t2jeff
I worried about the same thing when doing my kerdi shower this summer. Had a few spots with 3 layers in the corners. Didn't effect the tile at all.
I also constructed my own curb out of kerdiboard.....
Good luck!
Jeff
t2jeff is offline   Reply With Quote
Old 12-07-2017, 09:55 PM   #4
Welcome to the forum, Vic.
Your 1/2" notched trowel will collapse down to juuuuuuust a bit under 3/16". Knowing this, you'll have a better grip on making tiny adjustments to the mortar for the built up corners. Since you're already aware of the build-up, part of your battle is already won.
And as a method of dealing with this....If you're willing to wait for the mortar to dry, you could run a skim coat ahead of time to flatten the area out. It would make obtaining 100% mortar coverage under your tiles a bit easier.
Old 12-08-2017, 01:26 PM   #5
eartha5
thanks for the feedback
Appreciate you all chiming in. I will plan to just work around this spot with mortar to get everything pretty even. I am using a tile leveling system, so based on your comments here, I think I'll be in good shape.
I filled the shower and lost no observable water overnight, peaked in a hole in the drywall underneath the shower and saw no moist wood anywhere, so feeling pretty good about it all.
Gotta say it was a little trickier than i imagined to work with the kerdi-band. But from what I understand I still saved a lot of work over hardie-board. Just gotta band the joints and edges of the field of ditra-heat in the room, and I'll be getting tile down.
Vic
Old 12-09-2017, 09:02 AM   #6
Sounds like you're on your way, Vic.
Installed Kerdi-band over Kerdi-board but thinset seems fragile. Bonobo Tile Forum/Advice Board 7 03-14-2014 06:41 PM
Kerdi band same as Kerdi Waterproofing Membrane? pd154 Tile Forum/Advice Board 9 09-01-2013 11:57 PM
Adhesives question: Swanstone, Kerdi band, Kerdi aluminum edge profiles keithwwalker Tile Forum/Advice Board 8 02-19-2012 08:54 AM
Kerdi Shower Membrane and Kerdi-band For Sale duraleigh Tile Forum/Advice Board 7 10-14-2008 09:13 AM
How to avoid blisters on outside corners with Kerdi or Kerdi band Kirk Grodske Tile Forum/Advice Board 1 11-11-2007 03:59 PM
