Old 12-06-2017, 07:07 PM   #1
Superman07
Kitchen Backsplash Install
Good evening. We had our kitchen redone and opted to leave the backsplash off while we found the tile we liked best. We’ve settled on a 2x4 Mosaic glass subway tile.
The install will be over drywall. Manufacturer recommends modified mortar.
Removal of the old counter top and backer left some small holes (about the size of a quarter) and rips to the drywall. If I skim coat with drywall patch will this be sufficient or will it draw too much moisture from mortar?
From your experience how much slack is there on a gas stove hookup? I’d prefer to tile straight across even though the stove sticks up from the top of the counter.
Any other general suggestions or tips for the application area would be appreciated.
Thank you,
David
Sent from my iPad using Tapatalk
David
Superman07 is offline   Reply With Quote
Old 12-06-2017, 07:21 PM   #2
rmckee84
Skim coat is fine, then prime the area before tiling.
It just depends on how long the flex pipe is that's connected to it.
Ryan McKee
Old 12-06-2017, 07:38 PM   #3
You may be able to move the stove enough to work back there, David, but there should be a shut-off valve under there somewhere. Sometimes accessible under the stove via a removable toe-kick plate, sometimes you gotta pull the unit out as far as possible and get your best contortionist to reach down behind it. Then I'd disconnect the flex line and move the stove out of the way while tiling.
Old 12-06-2017, 09:15 PM   #4
What CX says. And I’m the contortionist.
If you’ve got a drawer at the bottom of the stove, pull it completely out at grab a flashlight to give yourself a sneak peek back there.
Old 12-08-2017, 07:42 AM   #5
Superman07
Thank you for the responses. It was my plan to pull out as far as possible and remove the bottom tray.
When grouting, it it recommended to skip the gap between the counter and leave open for caulk? Or caulk on top of the grout?
David
Old 12-08-2017, 08:12 AM   #6
Definitely use caulk between the backsplash and the counter top.
First time kitchen backsplash install 12x12 wall tile basic questions BCMike Tile Forum/Advice Board 9 04-26-2011 08:45 AM
Backsplash Install jryand17 Tile Forum/Advice Board 3 03-06-2011 06:15 PM
Install backsplash jupright Tile Forum/Advice Board 7 01-28-2009 01:30 PM
Backsplash Install- Do I have it right? angc2005 Tile Forum/Advice Board 4 04-05-2005 09:12 PM
Kitchen Backsplash... Okay w/ 4" ES backsplash? LPOWMACBACK Tile Forum/Advice Board 1 03-15-2004 07:17 AM
