Old 12-06-2017, 01:32 PM   #1
Bied10
crack fill under LVT
HI all. I know this isn't ceramic, but you all have never steered me wrong on any flooring advice.
I am going to lay glue down LVT over concrete (12 years old). I need to fill the expansion joints with something. I have thought about Silka because the cracks would still be able to expand and contract but "everyone" says to use a concrete patch. If I used concrete patch, the cracks will no longer work like they are supposed to.
My one big concern is if I use Silka (or something else that is flexible) will the LVT crack when a chair rolls over it or high heels (because you know how often people wear high heels in your basement).
Just looking for some advice from guys I trust. Thanks, Mike
mabiedenharn@gmail.com
Mike in Hilliard Ohio
I won't do a half ass job. Let me study it a bit so I can do a whole ass job instead.
Bied10 is offline   Reply With Quote
Old 12-07-2017, 01:53 AM   #2
How wide are the joints? Is it conceivable that something could rest on that crack and sink in?
Technically, you should use a solid material, like a cement-based compound to fill that joint, or leave it open and use a manufactured joint on top. Of course, if this is in the middle of a room, nobody wants that.
I would consult the guys over at The Floor Pro about this. There are several vinyl/linoleum installer's there that do thousands of feet every month. Tell them I sent you.
Old 12-07-2017, 04:52 PM   #3
Bied10
The joints are about 3/4" wide and about 1/2" deep. Each has a crack at the bottom (as designed).
There is a good chance of a chair rolling over them in one room, that is what I am worried about. All the recommendations are for a latex fortified cement fill, but that makes the cracks not work as designed.
I will ask your guys and tell them you sent me. Thanks.
(I will let you know what they said )
Old 12-07-2017, 08:32 PM   #4
Mike, what you're describing sounds more like a control joint, rather than an expansion joint, although I can't imagine what they were thinking in making it 3/4" wide and only 1/2" deep. A control joint's depth is usually a minimum of 1/4 the thickness of the SOG and no wider than a saw cut or grooving tool width.
I've not had any vinyl installed for years, but as I recall we just filled control joints with a Portland cement patching material and tiled over them.
To fill or not to fill ( waffles ) Hammy Professionals' Hangout 46 02-09-2013 11:38 AM
To fill or not to fill teamjenny Tile Forum/Advice Board 4 06-27-2010 11:40 PM
Fill in D&BT Tile Forum/Advice Board 16 11-13-2006 11:19 AM
What can I fill this gap with? jflenniken Tile Forum/Advice Board 14 01-02-2006 11:26 PM
what to fill the gap with??? mitcheal Tile Forum/Advice Board 2 01-09-2002 06:11 PM
