Old 12-04-2017, 03:53 PM   #1
CrashOverride
Crash's Bathroom Remodel
Hi all,
I'm beginning to work on remodeling our shower and I've been reading the forums as much as I can for answers. I'm ready to install the shower valve rough-in but I can't determine how far back to set it. I figure I'll have the following layers- green drywall (1/2") + thinset and kerdi (1/8") + thinset (1/4"?) + tile (3/8").
The tile we're using is 12x24 ceramic laid horizontally. My reading says to use a 1/2" square notch trowel and skim the back of the tile. That seems like it will leave too much thinset (possibly more than 1/4") between the tile and kerdi. I'm also worried it will be difficult to flatten the 1/2" ridges down. The tile seems to be pretty flat and kerdi overlap should be the only imperfections on the wall. What do you guys think, is 1/2" square notch plus skim the way to go? I put some pictures of the tile below if it matters.
Thanks for the help!
Brandon
CrashOverride is offline   Reply With Quote
Old 12-04-2017, 04:17 PM   #2
Maniac979
Maniac979's Avatar
Not a pro but I did a small mock-up to make sure I was locating the valve properly. If you are using a Kohler valve they make an extension if you bury the valve too deep in the wall. If you don't get the valve deep enough, you are in deep trouble with Kohler.
Ed
Maniac979 is offline   Reply With Quote
Old 12-04-2017, 04:38 PM   #3
rmckee84
Sounds pretty close +/- 1/8"
Ditch the greenboard and use regular drywall under the kerdi.
On tile that size I would suggest 1/2"x1/2", 1/4"x1/2" u notch, or euro notch. When you skim the back of the tile you do so with a a lot of pressure to essentially burn thinset onto the back which will aid in bonding. When you trowel the thinset on the wall do so in a single direction, parallel with the short side of the tile. Once on the wall slide the tile at least 1/2" perpendicular to the trowel direction this will collapse the ridges.
Ryan McKee
Old 12-14-2017, 04:07 PM   #4
CrashOverride
For the 12 x 24 x 3/8" tile mentioned above for our shower walls would you use regular Versabond or Versabond LFT?
Brandon
Old 12-19-2017, 11:49 AM   #5
CrashOverride
Anyone? Maybe I should ask a different way, what medium bed mortar would you use for those tiles over Kerdi? I looked at Schluter All-Set but didn't see good reviews.
Brandon
Old 12-19-2017, 12:00 PM   #6
rmckee84
Are you concerned with their "warranty"? If not there are a ton of great options. Any non-sag will work.
My favorites are
-Ardex x5 or x77
-laticrete tri lite
Versabond LFT will work but I'm personally not a fan.
Ryan McKee
Old 12-19-2017, 04:38 PM   #7
CrashOverride
Thanks for the help Ryan. I found a place near by where I can get Laticrete Tri-Lite. I also appreciate the info you provided in response to my first post regarding skimming the back of the tile and using regular drywall.
Brandon
Crash tests.... Anyone? Dog paws The Mud Box 1 09-29-2009 07:02 PM
Just why do computers crash and burn.... Dave Taylor Computer Training 0 02-14-2006 10:57 AM
plane crash tilesnake The Mud Box 15 08-04-2005 04:43 PM
Housing Market Crash John K The Mud Box 19 05-22-2004 02:42 AM
