Old 12-03-2017, 02:59 PM   #1
tilempls
Non Pigmented grout for Cement tile?
Hi all, I'm installing a black and white patterned 8x8 cement tile by cle.
After sealing with miracle porous plus and installing the manufacturer recommends using only non pigmented unsanded grout in a 1/16 joint.
Does anyone know of a true non pigmented grout on the market?
I've installed this tile before and even after several coats of sealant a test showed that the grout pigment severely stained the finish. After all was said and done I had to tape all vertical and horizontal joints and completed the grout in 2 passes. It looked great with no staining but was long on labor.
Natural grey was historically a non-pigmented grout but after reaching out to custom and laticrete it seems that all off the shelf grouts are pigmented.
Any help? Portland grout recipes?
P
tilempls is offline   Reply With Quote
Old 12-03-2017, 03:41 PM   #2
rmckee84
I can honestly say I have come across this. I know a lot of guys that use pigmented grout on cement tile without issue. Not to say they've installed the exact tile you're referring to. I would suggest a single component like Flexcolor CQ if not in a wet area. The color is actually in the quartz aggregate so staining wouldnt be an issue.
Ryan McKee
Replacing Cement Grout with Epoxy Grout....need info PDQ PeteINChicago Tile Forum/Advice Board 3 05-13-2016 04:47 PM
Cleaning Grout/Cement Mess off Marble/Onyx Tile Deanna519 Cleaning, Restoration and Sealing 1 12-17-2009 11:03 PM
Removing cement grout/tile adhesive from Tiles henriettaridgeon Cleaning, Restoration and Sealing 1 07-22-2007 09:13 PM
Heavily Pigmented Grouts.... michaelhazuka Professionals' Hangout 4 05-05-2007 06:48 PM
cleaning tile grout which seems to be cement mahnrut Cleaning, Restoration and Sealing 2 12-01-2004 07:15 AM
