Old 12-02-2017, 11:29 AM   #1
Mayatan
Freezing Prism Grout What are the effects?
As the title says, I have stored a pile of sealed in the bag Prism grout left over from jobs. The freeze thaw cycles have been plenty as itís stored in an unheated metal storage bib, in Alberta, for 4 to 7 years. The bags are totally sealed and dry. I was not aware till a few weeks ago that you canít let the dry powder freeze. So, what happens if I use some say in a cabin or low key area? Is it total garbage now or just not as strong as unfrozen powder?
SFG
Mayatan is offline   Reply With Quote
Old 12-02-2017, 11:40 AM   #2
Welcome, SG.
What does the manufacturer say about your situation?
While the calcium aluminate-based products differ from the Portland cement products, I've never heard that their shelf life is in any way improved. `Might actually be shorter.
I suggest you contact CBP before using any of that product for anything besides yard bunnies.
Old 12-02-2017, 12:12 PM   #3
Mayatan
CBP says ďKeep from FreezingĒ. Thatís it. None of the distributors will take returns on Prism Grout. Even if you buy then try to return in July. Iíll contact the guys on Seal Beach next week. I was just wondering what the ramifications are if it was used. Seems odd you canít freeze dry powder sealed in a cellophane bag.
SFG
Old 12-02-2017, 12:15 PM   #4
Mayatan
I was that kid that needed more of an answer than ď I said soĒ. If I gotta throw it out fine. No big deal, just looking for someone here that can explain it.
SFG
Old 12-02-2017, 12:34 PM   #5
I wouldn't use any grout that is 4-7 years old no matter which type it is. Just too risky and too much work to replace. Prism has Portland cement in it and cement doesn't get as hard when it gets old. I try to limit any grout I have to 1 year.
Old 12-02-2017, 02:11 PM   #6
I wasn't addressing the freeze/thaw part of your question at all, SG. With the age of the product, I just don't think that part matters at all. Like yourself, I don't know what effect freeze/thaw would have on the dry product, but I bet the chemists at CBP do. I'll axe'em.
Davy, it was my understanding that Prism was made with calcium aluminate cement rather than Portland, but perhaps it is a blend of both. You know that it also contains Portland?
I don't know much about the calcium aluminate cements except that they are sometimes used in "high early" types of concrete and for other purposes. Seems there are a lot more tile installation products being made with those calcuim aluminates these days, to the extent that there are changes being proposed to eliminate Portland as an indentifier in some of the ANSI standards for setting and grouting materials.
Old 12-02-2017, 06:20 PM   #7
Just In Tile LLC
Just In Tile LLC's Avatar
Like Davy I don't use grout that's more than a year old, I tell customers if they don't want the leftovers I'm just gonna throw it away, sometimes it changes thier mind and they keep it.
Justin
Old 12-02-2017, 06:36 PM   #8
Kelly, it is Calcium Aluminate instead of Portland, my bad. That explains why it gets hard so fast. From what I found, it doesn't cure any faster than Portland but hardens in 24 hours as much as Portland does in 28 days. Shelf life is 6 months. I can't say about how cold weather effects it.
Old 12-02-2017, 07:17 PM   #9
Thanks, Davy. The shorter shelf life makes sense to me, but I couldn't find it in the CPB literature.
Old 12-04-2017, 11:07 AM   #10
Steve Taylor
Technical Rep
Steve Taylor's Avatar
Prism is based on Calcium Aluminate cement. Calcium Aluminate cement hydrates faster and is more likely to pick up moisture from the atmosphere. While it is packaged in plastic, plastic does allow a very low moisture vapor penetration; low perm rate. Therefore Prism does have a 6 month shelf life, after that its strength will suffer. We do not recommend using Prism that is 4-6 years old for anything.
Prism should be installed when its temperature is above 50 F, so we advise that it is kept from freezing. If it is stored in freezing conditions, it should be warmed above 50 F before using.
Steve
Custom Building Products - Technical
Steve Taylor is offline   Reply With Quote
Old 12-04-2017, 07:58 PM   #11
I've used it many times, Steve and it's what I use now instead of Polyblend. I've had very few problems with Polyblend over the years but I like that Prism's color is very consistent and sets a little faster.
TEC AccuColor EFX Epoxy Special Effects 3 part epoxy grout Soup2Nuts Tile Forum/Advice Board 22 10-16-2010 09:51 PM
Freezing SpectraLok Pro Grout? wrk2891 Professionals' Hangout 4 06-29-2010 01:30 PM
Effects of solvent based grout sealer on water-based silicone caulk jagger295 Tile Forum/Advice Board 6 03-18-2007 01:27 PM
prism grout jkarl Tile Forum/Advice Board 19 07-26-2006 11:03 AM
Prism Grout Schluterman Professionals' Hangout 3 01-30-2006 06:40 PM
