Old 12-01-2017, 11:06 AM   #1
Trettini
Is My Countertop Dyed?
Dear Pros,
I ordered an Azul Macaubus quartzite slab that is blue in color. The person who fabricated the countertop and treated it with the sealant, says its dyed and this is the reason why his sealant left greasy blotches all over the countertop.
How can I check if it's really been dyed and the supplier lied to me?
If it has been, can a water-based sealant leave greasy stains on it?
Is there a way to remove the stains? Acetone didn't help.
Thanks a lot!
Trettini
Trettini is offline   Reply With Quote
Old 12-01-2017, 01:12 PM   #2
It'll take one of the stoner guys on the forum to tell you how you can figure out the dye issue. Sorry, can't help you with that.
Did you purchase the slab through the fabricator? If so, then this is an issue you need to take up with the fabricator. The buck stops with him or her. Not their supplier.
...However, if you bought the slab, then paid the fabricator to fabricate it, then you are much more on your own to correct this dye issue.
Old 12-05-2017, 02:54 PM   #3
fhueston
The following is what I use to tell if the slab is dyed.
1. Take a white rag and pour some acetone on the rag and wipe. If you get no color transfer to the rag go to the next step
2. Take some MEK and pour it on another clean white rag and wipe the slab. If you get color transfer its dyed
Fred
fhueston is offline   Reply With Quote
Old 01-25-2018, 02:05 PM   #4
Marble1
Check the underside for runs. Nearly all dyed stones will have visible runs on the bottom.
MATT
Marble1 is offline   Reply With Quote
Old 01-25-2018, 02:09 PM   #5
Marble1
P.s. I've never heard of quartz being stained. I don't think it's even possible. And it should not be sealed.
MATT
Dyed concrete shower pan Dbattel Tile Forum/Advice Board 1 06-11-2013 12:01 PM
Dyed granite streaks eascarlos Cleaning, Restoration and Sealing 2 10-19-2009 05:30 PM
can epoxy grout be dyed? Grout Girl Cleaning, Restoration and Sealing 11 09-19-2007 09:39 PM
Can grout be dyed before mixing? conscious pilot Tile Forum/Advice Board 2 11-10-2006 01:15 AM
Can Grout be dyed after sealing Doyle Tile Forum/Advice Board 5 02-01-2006 05:18 PM
