Old 11-16-2017, 04:57 PM   #1
euro notch trowel
Has anyone used the notched trowels with the euro style teeth. Rubi has one that they claim eliminates the need for back buttering. Its reported to give 90% coverage. I am wondering if it really works that good since back buttering
18x36 or larger is really a pain.
drwcal is offline   Reply With Quote
Old 11-16-2017, 05:27 PM   #2
Dave Gobis
da Man!
Dave Gobis's Avatar
I did trowel demos pretty much weekly for 10 years. Don't know that I would agree with 90% on a 18x36, but, it will be an improvement. The Euro and slant notch trowel never failed me and I made a point of not trying hard to be perfect. I was also doing 18's or 24's.
Old 11-16-2017, 07:41 PM   #3
They do put a lot of pooky down. More than the 1/2" notch...at least the one I was using did.
I used it on some 6x24 and had a lot squeezing up through the grout joints.
Old 11-16-2017, 07:56 PM   #4
Simplyjames's Avatar
I've tried several and just seem unable to get the feel of them. The upper right tooth doesn't hold and spread mortar the same way traditional trowels do so I end up making a mess.
Might be different on a floor. I really only do wall work. The concept of the things seems legit.
Sent from my iPad using Tapatalk
ACT certified installer #015
Simplyjames is offline   Reply With Quote
Old 11-17-2017, 04:55 AM   #5
Tile & Stone
Tried them but never really trusted their claim. Never full coverage when a tile was removed and checked. Was taught early on to back butter. With big tile its a must!
CTEF Certified Installer
Old 11-18-2017, 08:24 AM   #6
Tiger Mountain Tile Inc
tile lackey
I have one and use it sometimes but never as a reason to get out of back buttering. It works fine but I seem to have gravitated back to my 1/2 x 1/2 square notch. Not really sure why.
Jim Upton
Old 11-18-2017, 10:03 PM   #7
The big advantage is that the slanted notches fall over so when you're trying to embed the tile, there's already an even coating on the surface rather than high points and essentially voids. I think to get best advantage, you need to hold it at nearly a 90-degree angle so that the notches are tall enough to fall over and fill in the spaces between. If you hold it at a more typical 45-degree angle, they'll be too short, and you'll have nearly the same issue as with a conventional notched trowel...voids between the ridges.
They're very popular in Europe.
Old 11-19-2017, 05:15 AM   #8
Not So Senior Contributor
evan1968's Avatar
Henceforth the name "Euro notch"
Commercial Tile Installations
evan1968 is online now   Reply With Quote
Old 11-19-2017, 06:41 AM   #9
Peerless Tile
Tile Contractor
Ive used them....got a couple of them. I find that as they wear (quickly) they become less and less effective towards their claim. more of a novelty to me. I seem to have a 1/4x1/2 loop or a 1/2x1/2 in my hand most times to get the results I'm looking for.
SC Greg
Peerless Tile is offline   Reply With Quote
Old 11-20-2017, 07:46 AM   #10
By the time I tried a Euro trowel years ago I was already an old dog and found it tough to get used to. The only dog I know who's been at it longer than I is Gobis.
V-notch trowel bcor Tile Forum/Advice Board 1 01-05-2013 10:48 AM
U-Notch vs Sqluare-Notch Trowel? Dan Clark Tile Forum/Advice Board 23 05-25-2008 03:29 PM
Euro Trowel Foochacho Professionals' Hangout 15 03-31-2008 08:52 PM
where to buy online 5/16 x 5/16 V notch trowel golfgod04 Tile Forum/Advice Board 5 01-26-2007 03:12 PM
trowel notch size j bignoli Tile Forum/Advice Board 1 08-14-2003 06:05 AM
