Old 12-03-2017, 09:09 PM   #16
don't worry it is a mechanical lock, not chemical between the tiles.
Old 12-04-2017, 03:24 PM   #17
clifton clowers
I think I have made a huge mistake. I could use help figuring the best way forward. The short version is that I installed a mosaic floor with Laticrete 317 which the datasheet says not to do. It does not say why.
Here's how that happened: I previously installed a mosaic floor (over self leveler.) I decided I didn't like it, so I filled it in with feather finish so I could install something else over it. During that process, I found that the original thinset (Custom Simple Set) was still wet after 2 weeks where it was over Kerdi. I pulled that up and reset those tiles with Ardex x77 (leftover from using it on the wall).
More than a month later, when I was going to install the new floor, I figured I should use unmodified mortar since there was ultimately a waterproofing layer under considerable portions of the existing floor, and that's what Schluter said to use. I went to the store to get some Laticrete 272. There does not seem to be anything in the datasheet regarding mosaics.
Unfortunately, the store did not have 272, so I bought 317. I looked it up, and found an elf saying that unmodified, it is effectively the same as 272. And the bag did not say anything about mosaics. So I used it. And then, upon it feeling sandy and crumbly, I read the datasheet where it said not to.
Back to the question at hand - should I just expect the floor to fail soon? Or is this less dire that I think? I thought maybe epoxy grout could buy me a bit of time. Maybe not.
Clifton
clifton clowers is offline   Reply With Quote
Old 12-04-2017, 07:43 PM   #18
What Laticrete would have wanted you to do is mix your 317 with their 333 additive to make it a modified thinset mortar, but the 317 alone will bond the mosaic tiles well enough on its own if the tiles were properly set. Laticrete, as well as all other setting materials manufacturers with which I'm familiar, would prefer a modified thinset mortar be used with all ceramic tile, but there were many square miles of tile set before there were ever any modified mortars available.
I would worry more about the areas where you had that organic adhesive (Simple Set is not a thinset mortar, regardless what it says on the bucket, it's an organic adhesive, aka Mastic). Not sure what you might have done to remove the residue from that material before setting new tile over the area, but I'd be concerned about the long-term bond there.
Without more information on just where you set the mosaic tiles it's difficult to even guess whether you might have any heavy traffic or other such use that might affect the bond with your 317. If you got good coverage on the back of each tile, though, your chances of a lasting installation are good.
Old 12-04-2017, 11:43 PM   #19
clifton clowers
Thanks. That's reassuring. This is in a bathroom. There are only two people here so it is a reasonably low traffic room.
I removed the mastek pretty well. I was able to scrape nearly all of it off without damaging the substrate. This is all outside the shower, around the edges of the room. The tiles on the leveler are down really well. I tried to remove some, but couldn't. So hopefully they stay that way.
Clifton
Old 12-08-2017, 12:19 PM   #20
clifton clowers
What should the edge between a Schluter shower pan and a wall look like? That is to say - every picture I can find online shows a more or less straight, level edge. Ours is U shaped which is making installing tile tricky. Is this an incorrect install, or just something that happens?
Clifton
Old 12-08-2017, 03:09 PM   #21
rmckee84
Did you have to cut the pan down to fit the space?
Ryan McKee
Old 12-08-2017, 03:56 PM   #22
clifton clowers
Yes. I didn't do that part of the install. The shower is ~3'x4'. Along the 3 foot wall it is more or less level, but along the 4 foot wall it is down more than 1/2 inch.
Clifton
Old 12-08-2017, 06:06 PM   #23
rmckee84
If there is a dip in the pan my guess is that it got dented. I would expect the side that had to trimmed would be lower because as you go toward the drain the thickness of the actual pan is less. So in turn the trimmed edge ends up lower.
Ryan McKee
First mud pan issues Aludski Tile Forum/Advice Board 10 04-07-2014 07:24 PM
Creating corner on island with quartz and no corner or bull nose pieces Chicagorealestate Tile Forum/Advice Board 4 10-25-2013 06:27 PM
corner bead for drywall/cement board corner FJK Tile Forum/Advice Board 11 07-10-2011 02:33 PM
VCT Issues VCT Contractor The Mud Box 5 03-23-2011 11:31 PM
Am I going to have issues? england Tile Forum/Advice Board 6 08-21-2008 10:32 PM
