Old 11-01-2017, 03:10 PM   #1
pcm2a
White haze on tile floor
Bought a house and the shower tile looks great in the middle but out around the edges has a white haze to it. I thought maybe it was soap scum so I have tried various different soap scum cleaners and even DYI recipes like vinegar and dawn. So far I have made no change at all to the white haze.
What else could it be? I may pick up some CLR and see if that does anything to it.
Patrick
pcm2a is offline   Reply With Quote
Old 11-01-2017, 03:48 PM   #2
fhueston
All those scum removers are acid base and are going to ruin the tile. I would call in a pro and have them take a look. It may be a combination of soap scum and hard water deposits.
Fred
fhueston is offline   Reply With Quote
Old 11-01-2017, 07:28 PM   #3
pcm2a
Thanks! I was hoping for some tips on what I could try out at home. The bottle of CLR at the store said not for stone and I'm not sure if I have stone or tile so I skipped it.
Patrick
Old 11-01-2017, 10:40 PM   #4
Looks like you've got stone.
Can you concentrate on a tiny little area with your fingernail, plastic putty knife, or something to see if you can remove any of it?
Old 11-07-2017, 07:34 AM   #5
stu rosen
I agree with Fred-best to hire a pro. Most likely its a combination of efflorescence,mineral deposits and soap film (soap film occurs if you use bar soap). Also your change of the joints where your wall meets the floor need to be caulked. Moisture in the pan could be causing you some of these issues as well.
Stu
www.stoneshine.com
stu rosen is offline   Reply With Quote
Old 11-16-2017, 02:58 AM   #6
katilicous
That looks like adorable Lil Travertine tiles. Take a shower and bring a razor blade with you. At the end of shower see if you can scrape off the white like thin coconut flakes. If so, it's soap scum and hard water. If so, call Prosoco and see if they will recommend a product for stone that can safely remove it if the scraping is too much. You don't notice this stuff till it has a scrap able amount. Just wipe your razor between passes so it you pick up something gritty you won't dig it into your surface and leave scratches.
Sent from my SM-N910T using Tapatalk
Kati
katilicous is offline   Reply With Quote
Removing white haze from charcoal grout and gray haze from white stones jaydub_atl Cleaning, Restoration and Sealing 9 06-09-2016 12:39 PM
White haze on shower tile walls - Tilex? linelle Cleaning, Restoration and Sealing 4 10-17-2013 11:45 PM
Black grout haze on porous white tile nmbogas Cleaning, Restoration and Sealing 4 01-16-2010 10:30 AM
White haze on grout jimbo22s Cleaning, Restoration and Sealing 16 12-07-2009 11:04 PM
White Haze on tile and grout... HELP Rockzulu Cleaning, Restoration and Sealing 9 02-02-2006 09:46 AM
