Old 10-30-2017, 08:13 AM   #1
branimal
Jake
Replace/Repair lead pan shower
Iím redoing a bathroom in my home and wanted to just replace the tile and fixtures.
When I knocked off the tile I found what may be a lead pan shower.
The slope to the drain seems pretty consistent all around. The shower didnít leak - I used it daily.
I think I have a few options at this point:
1. Tile the shower floor
2. Red-guard the floor then tile.
3. Break up that top mortar bed and check the lead pan for damage. It could be 23 years old. Some of the cement board I removed was dated 1994. Iíve read that lead pans only last 25 -30 years or so.
4. If the lead pan isnít damaged, carefully pull up the lead pan and check for a preslope on the bottom mortar layer. I could also make sure the weep holes are covered with small pebbles.
5. Replace the lead pan with a pvc liner. Ensure there is proper sloping underneath pvc liner.
Now in terms of experience, I am pretty green. Iíve installed a schluter-Kerdi shower in my other bathroom. I have no experience with mud-jobs. Willing to learn.
Jake
branimal is online now   Reply With Quote
Old 10-30-2017, 08:41 AM   #2
Dave Gobis
da Man!
Dave Gobis's Avatar
Working with lead pans is a rare skill for even seasoned tradespeople. If you start pulling at it you are likely going to be replacing it.
Old 10-30-2017, 09:42 AM   #3
diddly
lead pan
Listen to Dave Gobis. That size with those angles would be an expensive copper pan and making up a membrane would require a very good and experienced person. If you can gently crack and remove the mud in pieces do so but stay away from the drain assembly for now. I would call in an EXPERIENCED PLUMBER who has at least some familiarity with lead and certainly Copper pan drains. May need a plumber or tin knocker comfortable with soldering irons if the drain loosens. But unless there are holes in the pan which I doubt, Hopefully, No reason you cant re-mud the pan and carry on. Be careful near the drain.
Good luck,
Bookie
Bookie
diddly is offline   Reply With Quote
Old 10-30-2017, 11:33 AM   #4
3. Looks like the top mortar bed is broken up already, Jake, so no going back there.
That said, there is no way I'd even consider trying to re-use a 23 year old lead shower receptor under any circumstances. Remove it completely and start over with a new traditional mud/liner/mud receptor or move up to a direct bonded waterproof membrane shower as you did in your previous project.
I'd recommend the USG Durock Shower System membrane this tile so you can see how much easier it is to install than the Kerdi system you used last time.
If you'll add a geographic location to your User Profile we'll be better able to guess whether you're in NYC or Boston.
Old 10-30-2017, 02:13 PM   #5
It would be a very rare instance where the lead (or copper) liner was installed over a preslope. Plumbing code requires the waterproof layer to be sloped to the drain. Neither tile nor the setting bed are waterproof, just not damaged by being wet. The waterproof layer is the liner. Now's the time to fix that.
Old 10-31-2017, 08:56 AM   #6
branimal
Jake
Thanks for all the advice.
One other item I did not mention is I am under a time constraint here. This property is my primary residence and I will be renting it out to get into a more affordable setup.
Based on everyoneís input I think the right thing to do is to replace the lead pan with a pvc liner or a direct bonded waterproof membrane. Watching some videos tells me that liner will me tricky to install given the showerís shape and limited access. Cutting a waterproof membrane would be a easier but no walk in the park.
Is there a third acceptable option? Can I re-mud or thinset the top layer to properly slope all around and fix the chunk of cement I knocked off? The top layer seems to be fairly intact sans that one chunk.
I know this is not the RIGHT solution. And I may have to replace it in the future. Iíll save some wall tiles in case I need to redo the job.
Btw, CX Iím in nyc. Howíd you guess? Lead pan only required in those cities?
Jake
Old 10-31-2017, 11:22 AM   #7
jlbos83
Really Cool Weekend Warrior
While the angles are fun, it would not be hard to use a sheet membrane. You can do it in sections, as long as you have the right overlap, so you don't have to come up with a whacky sheet to make it around all of the corners. A traditional liner would strike me as being much more difficult. Plus, with the sheet membrane, just one mud bed.
Jeff
It's a DRY heat!
jlbos83 is offline   Reply With Quote
Old 10-31-2017, 06:30 PM   #8
Jake, that material you've broken off does not look like deck mud to my eye and it looks like it's but one layer of two layers of something on that floor. Looks more like a concrete mix, which is not at all what you want for a final mud bed in a traditional shower receptor.
If you ask folks who have spent a lot of time in the remodeling business, you'll likely get a consensus opinion that's it nearly always saves time and effort if you remove everything you can in the remodel area and start fresh. That would apply even more strictly to showers in my experience. I've got to recommend you tear out that whole receptor/pan and build you a proper one from scratch.
When you're in a hurry is the most important time to slow down and do things right so you don't spend a lot of time doing things twice. I learned that when I was an air traffic controller. Sometimes there wasn't even time to do things once. Jake, that material you've broken off does not look like deck mud to my eye and it looks like it's but one layer of two layers of something on that floor. Looks more like a concrete mix, which is not at all what you want for a final mud bed in a traditional shower receptor.
Btw, CX I’m in nyc. How’d you guess? Lead pan only required in those cities?
I think NYC is the only place we read about on here where lead pans are actually required, Jake. Boston is infamous for wanting (but I don't think requiring) copper pans and they apparently favor lead, too. The rest of the nation seems to have at least moved up to PVC/CPE liners and much of the country accepts direct bonded waterproof membrane receptors. Y'all only about a hunnert years behind.
Old 10-31-2017, 06:57 PM   #9
branimal
Jake
Jlbos - yeah if Iím going to tear this out, Iím going with a sheet membrane. - durock as Cx recommended. I think I can get the angles right using an angle finder and practicing using cardboard a few times. Then trace the correct cardboard template on the sheet membrane. If I get a large enough membrane, the slopes should all be correct.
Jake
Old 10-31-2017, 07:03 PM   #10
branimal
Jake
Cx - Iím going to take a closer look at that material. I know at one point the shower leaked and the prior owner had it repaired. This could be part of his repair. Iím really not sure.
ďWhen you're in a hurry is the most important time to slow down and do things right so you don't spend a lot of time doing things twice.Ē
This is sooo true. If I had a penny for everything Iíve done 2 or 3x.....
Jake
Old 10-31-2017, 07:06 PM   #11
branimal
Jake
While debating the complete tear out and rebuild with durock or Kerdi membrane option i came across another option.
I spoke with someone at Custom Building Products and he walked me through using Red-gaurd over the top layer of pre sloped mortar. The Red-gaurd serves as a shower liner (PVC or lead pan in my case). It seems like a simple fix to faulty shower pan issues.
Here is the CBP diagram: http://www.custombuildingproducts.co...5830/CB421.pdf
Here are the steps from what I understand. Iíve never seen a shower drain assembly so feel free to correct my errors in describing it.
1. Cut around the existing drain 2-3Ē large than existing drain hole using a dry cutting blade on an angle grinder. Tap with hammer and chisel as you get close to the drain assembly.
2. Remove the three drain flange bolts (pray that they are not rusted out). Remove the upper flange and bolts.
3. Cut a 45 degree angle to the drain all around the drain. See attached image.
4. Replace upper flange and bolts with new cast iron or plastic./ABS
5. Repair the shower floorÖ (broken chunk in prior post).
6. Ensure 1/4Ē / foot slope all around. Can use portland paste, thinset, etc.
7. Paint the entire shower floor and slope to the drain.
8. Stack pebbles on the weep holes.
9. Cover 45 degree angled hole with mud ensuring slope is 1/4Ē per foot
I may have missed some steps or mis-ordered things. Anyone have thoughts or experience with this method?
Jake
Old 10-31-2017, 07:30 PM   #12
There's no way I'd do it that way. Rip it all out like CX said.
Old 10-31-2017, 08:21 PM   #13
Liquid applied membranes can work, but it's not as simple as painting a wall. Getting the paint applied within the min/max without pinholes, runs, or voids is harder than you'd think until you get some experience. With a sheet membrane, you're worrying about getting the seams done right, but the membrane itself is entirely waterproof all over.
ALso, with a surface applied membrane, either liquid or sheet, you really should go at least up to the height of the showerhead. Otherwise, moisture from above might get trapped behind it on its way down.
Old 11-01-2017, 06:58 AM   #14
branimal
Jake
Jad - I agree, applying red-gaurd correctly takes experience. I have painted a shower wall with Red-gaurd (3 coats) but I cannot say for certain Iíve done it right. Time will tell.
That said, I am not solely relying on the red-gaurded floor for waterproofing. I still have a working Lead pan underneath. If I do end up with pinholes / voids that water should run down to the lead pan and flow to the drain. Thatís the theory at least. Iím not sure how cutting that 45 degree angle to the drain will affect the lead pan.
I just want to know my options before I remove the mud bed.
Regardless of which option I go with, I will be red-guarding the shower walls to 95Ē (ceiling height). And tiling all the way up. That will be at least a foot above the shower head.
Jake
Old 11-03-2017, 10:23 AM   #15
branimal
Jake
Ok enough horsing around. Iím breaking up the mortar. Will take pics along the way.
Cx, why do you say the durock is easier to work with than the Kerdi product.
Jake
Shower Question - Replace both or just repair the problem? jsebastian Tile Forum/Advice Board 11 02-02-2015 06:21 PM
Repair or Replace this mud shower pan? Cgiff9 Tile Forum/Advice Board 19 07-21-2014 09:32 PM
Shower Pan Leak - Repair or Replace? Winkinwino Tile Forum/Advice Board 13 11-17-2006 10:44 PM
Repair/replace shower floor Mella Tile Forum/Advice Board 1 07-31-2006 12:07 PM
shower pan repair/replace? johnmctile Tile Forum/Advice Board 8 08-28-2003 04:38 AM
