Old 06-15-2017, 08:17 AM   #1
TipsyMcStagger
Problem with tumbled Marble over RedGard?
I've chosen (and already purchased) a 3x9 tumbled marble tile for my guest bath. It's being installed in just a few days. In searching this forum for information on sealers, I came across this statement:
Originally Posted by Someone in another thread;
...be aware a marble job over RedGard could take weeks to dry out enough to see if it's gonna get gray,which is happening a lot lately from moisture and iron oxide in the stone
I'm not sure what to make of this. Are there known issues with marble over RedGard? This a a guest bath with a tub. I installed Durock with RedGard in the tub surround and will be tiling with the 3x9 tumbled marble from the tub to the ceiling and up to 48" around the rest of the room on green drywall.
Brad
TipsyMcStagger is offline   Reply With Quote
Old 06-15-2017, 10:10 AM   #2
Shady at Best
Tyrone shoelaces
Shady at Best's Avatar
I think the main concern is marble in a shower pan.
I am curious what the others will say
Sent from my SM-G935V using Tapatalk
Travis
It's just a clever handle.
Old 06-15-2017, 11:20 AM   #3
Brad, if you'll visit our FAQ you'll find a brief tutorial on how to post and properly attribute quotes here on the forums. Very simple once you see it.
Travis, it doesn't appear he's constructing a shower pan.
Brad, I don't know that there is or has ever been any problem installing marble, or any other tile material over RedGard. What whomever you're quoting there had in mind is that installing over any direct bonded waterproofing membrane is going to delay drying of the bonding mortar and potentially the tile if it's something like a natural stone. Whether you'll have any problem relating to that with your tumbled marble on your walls won't be known until you do the installation. Worst case, you'll need more drying time after the installation than you might with a different backing material. You'd notice any such issues far more with a polished or honed stone finish.
You'll need to consider the effect of the stone being regularly wetted in a shower installation.
A photo of your tile may help others with their evaluation.
Old 06-15-2017, 12:23 PM   #4
Shady at Best
Tyrone shoelaces
That's why I said that I thought the main concern is with pans.
Travis
Old 06-15-2017, 12:29 PM   #5
TipsyMcStagger
Right. No shower pan. Marble tile on walls above tub (over RedGard) and same marble tile around the room as a wainscot.
Thanks. On the plus side, it is a guest bath and the shower will be used infrequently.
Here is a link to the 3x9 tumbled marble subway tile. And here is a link to the Carrara marble mosaic that will be on the floor (concrete slab) and in the back of the shower niche.
The installer is suggesting Bostik Neverseal grout. I'm surprised to not find many mentions of Neverseal on this forum.
The tentative plan is to seal the tile prior to grouting. Type/brand of sealer and grout are still to be determined.
Brad
RedGard problem Tilerabby Tile Forum/Advice Board 9 07-21-2014 09:10 AM
Tumbled Travertine Color Problem chill4 Cleaning, Restoration and Sealing 14 04-01-2013 06:02 AM
RedGard Problem jamrock flooring Tile Forum/Advice Board 32 12-18-2012 07:53 PM
Redgard problem? brian.brown19@gmail.com Tile Forum/Advice Board 13 09-30-2012 08:47 PM
Redgard problem mike82657 Tile Forum/Advice Board 4 05-02-2007 05:47 AM
