Old 12-16-2017, 10:25 AM   #226
dave.adams
dave.adams is offline   Reply With Quote
Old 12-28-2017, 01:57 PM   #227
dave.adams
How long does latasil need to cure before it is safe to use the shower? Also presuming that 12 hours for spectralock epoxy is sufficient time to cure before using shower if Iíve understood manufacturer instructions correctly?
Thanks for all the help
Old 12-29-2017, 09:59 AM   #228
dave.adams
I found the info online about 24 hour cure time but Iím a bit confused on temp conditions. They say 70 degrees at 50% humidity. This is probably a dumb question, but the shower is obviously inside my house (shocker), and itís about 70 with our heat on, though itís 30 outside and 76% humidity... does that affect cure time or as long as temp and humidity inside is around the recommendations, still 24 hours?
Old 12-29-2017, 11:20 AM   #229
rmckee84
I usually tell customers 72 hrs minimum on everything unless the material states otherwise.
Ryan McKee
Old 12-31-2017, 01:35 PM   #230
dave.adams
Makes sense. Almost finished but ran out of silicone on the last seam I needed to do. The tube I ordered doesnít get it till Tuesday.
I know I should probably just wait and finish it, but if I started to use the shower for a couple days, itís not really gonna do any damage right? Water can get around tile at the edge where there is no silicone, but since everything is waterproofed will that really matter over the course of 4-5 showers?
Old 12-31-2017, 03:49 PM   #231
In a properly built shower it doesn't matter whether you have any grout or caulking in the tile surface at all, Dave. Well, not until time to clean it, of course.
The big concern with what you wanna do is getting soap or other cleaning products in that gap before you install your sealant. Other than that, I see no problem, but without a photo of where the missing caulking is located it's difficult to tell.
Old 12-31-2017, 03:54 PM   #232
dave.adams
Makes sense. May as well just wait. Itís been several months, couple more days wonít do anything but continue to compromise my wifeís sanity.... .
Thanks for all the help guys, this forum has been invaluable as it is always a crapshoot on the internet of knowing what and who to trust in terms of information. Appreciate all the pros and experienced folks taking time out of their day to help the rookie DIYer.
Itís not perfect but itís near complete, which is its best quality. Ha.
Old 12-31-2017, 06:03 PM   #233
Nice looking shower.
Old 02-23-2018, 01:18 PM   #234
dave.adams
Not sure if I should start a new thread for this, just had 1 question about doing a backsplash in my kitchen. Thereís some sort of sheet of laminate or something on the backsplash right now and Iím wondering if I need to rip it off or can tile directly on top of it for the backsplash?
Thanks a lot!
Old 02-23-2018, 06:11 PM   #235
mullet
mullet's Avatar
Outstanding job Dave!!!!
chuck
my first Kerdi Shower
Old 03-05-2018, 02:07 PM   #236
dave.adams
Attachment 200768
Attachment 200769
Thanks a lot!
Old 03-05-2018, 02:57 PM   #237
Carbidetooth
Hmmmmm
Carbidetooth's Avatar
It sucks sometimes to have an eye for the details but I think you have your shower head arm reversed. The longer end typically goes into wall with shorter attached to head. Moves the head away from wall so one doesn't bean themselves when rinsing hair
Peter
Doc's MB Shower Remodel DIYMAK Tile Forum/Advice Board 23 03-13-2009 05:45 PM
Shower remodel - Kerdi Shower Floor?? mirage505 Tile Forum/Advice Board 2 02-02-2007 07:58 PM
Tub/ shower remodel pitterpat Professionals' Hangout 7 11-13-2005 07:27 PM
Shower Remodel cal Tile Forum/Advice Board 3 02-09-2004 06:24 AM
Shower remodel GGL Tile Forum/Advice Board 16 02-28-2003 09:03 PM
