Old 11-06-2017, 06:41 PM   #46
MisterJJ
Knocking ridges flat... Thanks for the reminder. I had read about doing that for mosaic a while ago but that piece of information got pushed out by all the other shower/tile knowledge I've been trying to absorb.
I think I'll try my 1/4" x 3/8", held at a low angle. Knock the ridges down and see how it looks. It never occurred to me to just try and see how it works and if it doesn't, just clean up the thinset and try something else.
Joe
MisterJJ is online now   Reply With Quote
Old 11-06-2017, 08:13 PM   #47
rmckee84
With a mosiac that size I wouldn't go bigger than 1/4"x1/4". Anything bigger and you'll end up with a mess.
Ryan McKee
Old 11-06-2017, 08:36 PM   #48
greenjp
Concur. I set my 2x2 floor tile with a 1/4" notch and still had a fair bit of mortar come up in between. It wasn't what I'd call a mess, but I had to clean it as I went with a toothbrush, and then again with a grout scraper/saw prior to grouting. I used a 1/4x3/16 v-notch for a linear mosaic I used for some trim and had a similar amount come through.
jeff
greenjp is offline   Reply With Quote
Old 11-06-2017, 11:03 PM   #49
MisterJJ
Looks like I may not end up with the 1" x 2" mosaic anyway.
My field tile arrived at Homers and I checked how well it matched the 2" x 6" bullnose and it didn't match well at all. Actually, I took a closer look at different tile and bullnose and found that they didn't match at all either. So the search for tile begins once again.
If nothing else is found I may end up with the original tile and use the edge profiles that everyone else seems to like. I must say that I don't dislike them as much as when I first saw them.
Joe
Old 11-21-2017, 02:51 PM   #50
MisterJJ
Dropped the Homer tile. None of their bullnose matches the field tiles unless it's plain white.
I found some comparable tile at Arizona Tile for just a little bit more and the bonus is that it's rectified. Tiles seem to have a little bit of dome, but not bad. Mosaic is 2" x 2" but it's really 2 1/8" x 2 1/8" with 1/8" spacing, which makes the tiled drain problematic, but I think I can make it work.
I got my first piece of Kerdi up!
This is my Jesus board, where I can be forgiven for the sin of picking at the corners.
Joe
Old 12-04-2017, 03:18 PM   #51
MisterJJ
I just don't get it. I'm almost done with the Kerdi install but I keep looking up thinset mixing information because my results just don't seem to match what I'm reading. I measure out the water, add the thinset and start mixing with electric motor. For the first 30 seconds it's more lumps than anything else. After about 2 minutes I'm down to an even spread of a few dozen lumps. At 4 minutes I'm still chasing a few small lumps around and finally at 5 minutes I'm down to only a tiny lump or two. I'm probably running the mixer on the fast side but running any slower I still have lumps at 5 minutes. I spend the entire time constantly rubbing the mixer around the side of the pail to mash out the lumps.
Same results on two bags of thinset from two different stores. Dry mix has no lumps in it.
I watched the following video and was like WTF?!? he spins a margin trowel around for 20 seconds and has perfectly smooth thinset?!?
https://www.youtube.com/watch?v=9lUWxzoMD5o
Joe
Old 12-04-2017, 04:49 PM   #52
rmckee84
What kind of paddle are you using?
What kind of drill?
What thinset?
Are you measuring both the water and powder?
Is there lumps I'm the bag?
Ryan McKee
Old 12-04-2017, 07:12 PM   #53
MisterJJ
Twirly mixer, like this: Twirly
Using old variable speed motor. Try to keep it less than 1/2 of full RPM.
Versabond.
Measuring both. A full quart of mix and about 13.5 oz. of water. Holding a notch, but about as well as I would hold my mother-in-law from falling off a cliff.
No lumps at all. I lift a margin trowel of powder up and shake it off slowly... no chunks.
Joe
Old 12-04-2017, 07:58 PM   #54
rmckee84
I got nothing, there are better paddles but that one wouldn't cause lumps I would assume.
Mixing speed can be important to some thinsets.
Versabond is bottom of the barrel stuff in my opinion but it should still mix up.
Try adding powder to the water while mixing, it sounds like youre dumping water then powder then mixing.
Are you letting it slake then remixing?
Ryan McKee
Old 12-04-2017, 08:15 PM   #55
Redlands Okie
MisterJJ Shower with a Newb!
Obviously your using hard water and its causing the lumps . ya just kidding. Mixing in large amounts of powder into little amounts of water could easily be a issue. How about adding the powder to the water in smallish amounts as you mix. As stated above slaking helps. Gives time for the water to penetrate any lumps as well as allowing the chemical process to start kicking off.
Robert
Old 12-04-2017, 08:43 PM   #56
MisterJJ
I was a bit paranoid about going too fast and introducing air when I first started but I would get to 5 minutes of mixing and still have lumps so I gave up on that and run it faster to get all the lumps out without going much past the 5 minutes.
I am just dumping the measured dry mix into a bucket that has the pre-measured amount of water. I've been doing this as a convenience of leaving the dust cloud outside and bringing it in to do the mixing. I did try to not add all the dry mix at once before starting to mix but even then I was starting with lots of lumps and having to beat them out.
Definitely letting it slake for about 6-7 minutes and then remixing. If I had small lumps before slaking I would have small lumps after. At first I thought it was like cake batter... "small lumps will disappear during baking"... or slaking, but I found that was not the case.
The lumps aren't chunks of dry mix. When I isolate one and break it up it is just a less-liquidy lump. Kinda like a chunk of "dry-pack".
Maybe there's just a stock of older stuff that I got ahold of. I tried finding a date code but there wasn't anything that I could find. Almost done anyway. Just Kerdi-Band to go, so I'll beat my way through. I'll be really pissed and confused If I have the same issue with the Pro-Lite stuff for the tile.
Joe
Old 12-04-2017, 09:55 PM   #57
What Robert said, add the powder slowly into the water while mixing.
Old 12-05-2017, 07:51 PM   #58
MisterJJ
"add the powder slowly into the water while mixing"
It worked! Big difference. Thanks guys!
I thought I was saving myself the trouble of dust clouds in the garage or running the extension cord outside when I chose to dump the dry mix into the water outside and use the drill motor inside, plugged into the wall. Yeah, being lazy too. So I dug out the extension cord and mixed as I dumped and it was much, much better.
Joe
Old 12-13-2017, 09:20 AM   #59
MisterJJ
Ready for flood test (I think). There are some minor issues with my Kerdi install, but I think they're acceptable. The outside corners were a major pain. No matter what I did they pulled up where they had been creased to lay flat for packaging. I had to rig up blocking to press against these areas while the thinset cured.
I had one area where the edge pulled up slightly on the floor. I don't think it's a problem.
On the inside of the curb the Kerdi outside corner wrinkled a bit at the bottom. This happened after squeezing out the thinset so it's loose. There's an inside corner behind it so I think it's okay.
I did the floor in one piece and then wrapped another piece over the curb and over the floor, not realizing that having to do the corner pieces would give me 4 layers of kerdi on the floor at the inside corner of the curb. I plan to skim coat with thinset before laying tile to smooth out the transition.
On the top edge of the tub, which will be in the shower, I used a finished edge of the CBU to give it a bit of a downslope into the shower. This also gave it a radius on the edge. When doing the Kerdi outside corner it stayed mostly square so there's a gap (filled with thinset). This edge is opposite the shower head so it will see a lot of water. I think I'll just dab some Kerdi fix pooky in the corner.
Joe
Old 12-13-2017, 09:55 AM   #60
makethatkerdistick
Joe, I had similar issues with the Kerdi. It's the nature of a sheet membrane, I think. My flood test was successful. Yours will be, too.
As much as I like Kerdi, I don't think it's actually that easy to work with (as everyone says). Plus, I did the overlap method for my 45 deg. corners that leave a tiny pinhole. But according to Schluter, that's absolutely fine. They have a video for that. You can actually waterproof your shower without using their prefab corners. And to my knowledge, they don't make 45/135 deg. corners currently. But that was just an issue for my application.
Good luck. And go the whole 24 hours. You'll feel better that way.
Wolfgang
makethatkerdistick is online now   Reply With Quote
Newb tiling above shower RMack Tile Forum/Advice Board 5 09-19-2011 11:14 PM
News Flash! Not so NewB NewB says hello! ronbo1100 Professionals' Hangout 10 02-04-2011 09:10 PM
Newb Shower Questions etulfer63 Tile Forum/Advice Board 8 10-07-2009 09:46 PM
Newb looking to take it all on....(Schulter shower system) reilinjw Tile Forum/Advice Board 42 01-24-2008 09:09 AM
Newb needs help with custom shower Bert Tile Forum/Advice Board 9 09-26-2004 03:56 PM
