Old 01-11-2017, 02:46 PM   #1
TRex10
Another Shower Remodel Question
Background: 1970's brick home on concrete slab. Standard tub and tile job in track home. Shower wall basically caved in at faucet handle.
Tore out everything down to studs. Replaced galvanized with PEX/Sharkbite to main header. Replaced some studs, adding some studs.
Replacing tub with walk in shower using hardie concrete board and Goof Proof Pre-pitch/Perfect-pitch system - probably throwing in a bit of waterproof paint for good measure.
My Question: How to I handle the huge hole in the slab surrounding the existing tub drain? Obviously not a problem when there was a steel tub there but since I'm going to be laying a mortar bed... now it's a problem.
My solution is to back fill with peagravel/sand mix - pack tight to an inch of foundation level - then mortar it in with the mud mix. (obviously after I've set the new drain.)
Are there any other suggestions? Problems with my solution?
Thanks in advance.
Toni
TRex10 is offline   Reply With Quote
Old 01-11-2017, 03:45 PM   #2
Welcome. Please replace that permanent signature line with a first name for us to use.
I'd first pull out the plastic liner, then fill the hole to the bottom of your concrete slab with a packable material, then fill to the top of the existing slab with a concrete mix leaving a void sufficient for attaching your drain or after installing your drain.
Old 01-12-2017, 12:00 PM   #3
TRex10
Smile Thanks!
yeah, I've rethought the pea gravel part... t got stuck in my head due to a youtube video I watched... He also used expanding foam and I said, oh hell no..... I would mix and pack it with sand....then thought... why would you do that - just make it all sand....
Thanks - I just wanted to make sure I wasn't overlooking something stupid. The other showers I installed were wood floor construction.
I can't think of anything catchy to add to my signature!
So it's just - Toni
Toni
Old 01-29-2017, 01:46 PM   #4
TRex10
I've gotten the shower pan poured including 40mil liner, hardieboard up, waterproofed with redguard, ledger boards set. Picked up my tile and the guy at the shop sold me this set: Crest Porcelanato.
Afar I'm poised to start,I'm concerned using this in shower floor and walls with ceramic tile.
Do? Don't?
Toni
Old 01-29-2017, 02:39 PM   #5
A link to the product(?) in question would help, Toni? Not sure if you're talking about a tile or something else there.
Old 01-29-2017, 03:09 PM   #6
TRex10
Sorry about that.
Thinset brand Crest. Porcelanato
http://www.crest.com.mx/eng/?page_id=11613v
This is the manufacturers site but the exact thinset isn't there.
It states in the package that it's for porcelain or low absorption tile.
I'm using ceramic 12x24.
I'm heading to Lowes/Home Depot. Versabond or Mapei.
Even though the guy said it was fine.... I'm not sold.
Thanks for all the help! This forum is amazing!
Toni
Old 01-29-2017, 08:54 PM   #7
I know nothing about the product at all and I've never heard of the company. I do see the mortar on the link you posted, but it's not in English. Only think I could read was that it exceeds ANSI A118.4 and would, technically, be a suitable product for your application.
Use it if you wanna. Not likely to find many comments here on our forums about it. I found one reference from 2009 from one of our Canuck members saying the company had been bought out by Custom Building Products.
If you're got access to VersaBond, I'd favor that over an unknown product.
Old 01-30-2017, 06:07 AM   #8
TRex10
Thanks! I agree.
Toni
Old 01-30-2017, 07:22 AM   #9
Todd Groettum
Theoriginaltileguytodd
Crest is ANSI certified and Has the Older TCNA certification....That said, Mapei products ( example Ultraflex II ) or Laticrete's 253 gold, OR of course Custom's Versabond are well known and well respected products..
theoriginaltileguytodd
Todd Groettum is offline   Reply With Quote
Old 01-30-2017, 08:16 AM   #10
When did the TCNA start certifying products, Todd?
Old 01-30-2017, 02:03 PM   #11
TRex10
Here are some photos from my ongoing bath remodel.
Toni
Old 01-30-2017, 02:36 PM   #12
TRex10
I plan on installing a 'barn door' over the main entrance of the bath area, since I demo'd the door to the toilet/shower area and modified the wall into a pony wall.
I've used the Goof-Proof shower system (seemed like a good idea at the time).
I will spend the extra and go for the Schluter/Kerdi system.
I'm laying out the tiles now...
Toni
Old 01-30-2017, 02:40 PM   #13
TRex10
The galvanized plumbing was literally disgusting. I replaced these lines back to the header with PEX.
Toni
Old 01-30-2017, 02:45 PM   #14
TRex10
The pour was not as pretty as I had hoped for but... I think it will do.
Toni
Old 01-30-2017, 02:58 PM   #15
TRex10
I've done a complete kitchen including counter tops and walls as well as enclosed the window ledges, etc... I took my time and was creative with the patterns. I've done a couple of bathroom lavatories and replaced a couple of rows tile with a tub replacement from steel to cast iron.
This will be my first full wall with large tiles. I'm really antsy about it...
I picked up -
https://www.lowes.com/pd/MAPEI-Porce...Mortar/3743821
instead of using the Crest Porcelanato that I bought with the tiles.
but I noticed that it is "polymer enriched".
I flip-flop on the mortar from "everything's going to be fine" to "OMG I'm totally screwing up"....
Toni
Shower remodel question CltPack Tile Forum/Advice Board 8 02-28-2016 01:05 PM
Shower Remodel - New with Question's rjjencke Tile Forum/Advice Board 77 09-17-2012 10:26 AM
Shower remodel question(s) madduxx31 Tile Forum/Advice Board 2 05-21-2012 09:47 AM
shower remodel Question: jnsebastian Tile Forum/Advice Board 4 08-25-2011 08:48 AM
Shower remodel question sdavis Tile Forum/Advice Board 2 10-05-2005 09:19 PM
