Old 01-12-2002, 07:32 AM   #1
Hi everyone:
I'll be spending my weekend repairing the grout in my shower, and I'll be pondering this question:
How is caulk different from grout? What are the appropriate applications for each?
And, more specific to my project--do I use caulk between the bottom-most row of tiles and the plastic shower pan? Or does that get grout, too?
shkessler is offline   Reply With Quote
Old 01-12-2002, 09:58 AM   #2
Hi Sandra,
Grout is cement, the original stuff between the tiles. Caulking is flexible -- gooey when wet and like rubber when dry.
You would use grout between the tiles and caulking down by the shower base.
But when grout falls out there is always a reason, and often that reason is moisture which has gotten into the material behind the tiles. If that material is sheetrock (wallboard), you may want to do a little more than re-grouting. At the very least you need to let everything dry out thoroughly before you apply the new materials. It could take a few days.
