Old 11-25-2017, 08:45 PM   #31
BimmerRacer
Not a pro
BimmerRacer's Avatar
Hmmmm....
-- Jason
BimmerRacer is offline   Reply With Quote
Old 11-26-2017, 08:27 AM   #32
BimmerRacer
Not a pro
I was almost sold on the 3/32" but I don't think it'll work as well vertically. I have 78 1/4" which is translates, at least on paper to 26 rows with 1/8" on top and buttom. Tiles are spec'd and measured at 75mm (weird TileShop metric sizes, not sure why) which is 2 15/16". if I go with 3/32" spacing it puts me 13/16" over the height
-- Jason
Old 11-26-2017, 09:59 AM   #33
wwhitney
Yeah, I was wondering about the height. Bummer.
You could try laying out on the floor a 54% offset and see if it is noticeable that it is not 50%.
Are you planning to wrap the tiles around the corner? If so, have you checked whether the various options discussed will leave you with slivers at the ends of the short walls?
Are the walls all plumb and square?
Cheers, Wayne
Wayne
wwhitney is online now   Reply With Quote
Old 11-26-2017, 05:11 PM   #34
BimmerRacer
Not a pro
The walls plumb but with a slight vertical wave. No wrap around the corner as the subway glass is only going up the back wall. Sides are getting 8x20" marble
-- Jason
Old 11-27-2017, 11:27 AM   #35
BimmerRacer
Not a pro
Hydroban over taped/thinset joints - how soon? I added a niche
-- Jason
Old 11-28-2017, 03:51 PM   #36
BimmerRacer
Not a pro
Another question about the niche. I am using a double which has a 12 and 6" opening. The 12" has quite a bit of flex when I am pushing in the back. Is this normal? It's installed to the Laticrete instructions with blocking on 4 sides, adhesive and taped joints. There's nothing in the instructions regarding support for the actual back of the niche.
-- Jason
Old 11-28-2017, 05:58 PM   #37
rmckee84
Its fine, once its tiled you won't have any flex
Ryan McKee
Old 11-28-2017, 08:19 PM   #38
BimmerRacer
Not a pro
-- Jason
Old 12-01-2017, 05:51 PM   #39
BimmerRacer
Not a pro
Planning on starting to tile this weekend with the glass subway tile on the back wall. Few final questions
- trowel size for the subway tile? I have 4-XLT and will be using that if it matters.
- keeping thinset out of the joints and keeping the tiles clean without scratching them with thinset? Any pointers there?
-- Jason
Old 12-01-2017, 06:20 PM   #40
rmckee84
1/4"x1/4" will probably suffice, I would comb out the thinset then knock the ridges flat by using the flat side of the trowel perpendicular to your ridges.
Not sure 4xlt is a good choice for glass. I would go with something else personally. I would also opt for a white thinset.
Wet sponge and denture brush for cleaning out the joints. Have a bucket of water close by just for those.
Ryan McKee
Old 12-01-2017, 07:56 PM   #41
BimmerRacer
Not a pro
Thanks Ryan
What's the purpose of knocking down the ridges?
4-XLT is white, at least mine is. Laticrete said it was fine for both glass and larger marble?
-- Jason
Old 12-01-2017, 08:16 PM   #42
rmckee84
If they say its good then go for it. Even with a backing on glass the ridges can show through the edges of the tile and cause shadows and lines.
Ryan McKee
Old 12-07-2017, 12:28 PM   #43
BimmerRacer
Not a pro
So it looks like I have some unevenness (max 1/4" but mostly less). So, the plan is to float some XLT over the back wall to get it even, let it dry and set tile over it using Custom's glass tile mortar. Lesson learned about being more thorough about checking the flatness of the wall prior to install. I didn't a level which I could use straight across the back wall, so, instead I used one that was longer, diagonally, which apparently lied
-- Jason
Kyle's Basement Bath remodel prostuff1 Tile Forum/Advice Board 54 09-04-2012 10:57 PM
Basement family bath remodel dianelouise Tile Forum/Advice Board 32 12-02-2009 10:00 PM
Erika's Basement Bath Remodel- etile Tile Forum/Advice Board 13 03-16-2008 09:32 AM
Basement Bath Remodel dcgauger Tile Forum/Advice Board 48 03-19-2005 07:42 AM
basement bath remodel sherm Tile Forum/Advice Board 8 03-21-2002 07:48 AM
