Old 08-15-2016, 05:28 AM   #1
skydivingcat
Basement Bathroom
I am finally finished with the rest of the basement and it is now time to move to the bathroom. It is a small bathroom with a low ceiling. I was originally thinking about a curbless shower but I am not sure I gain anything by not having a curb. I still want to recess the pan so it is not a step up to the shower. If you use a foam curb how do you attach the shower doors? The model I was looking for on line all seamed to have a screw into the curb on the fixed glass.
David
skydivingcat is offline   Reply With Quote
Old 08-15-2016, 06:02 AM   #2
Regardless of the composition of the curb, I wouldn't allow for any screws through the top of it. The screws would likely penetrate the waterproofing layer and cause an eventual failure of the shower.
The.glass or.metal tracks on the curbs are sealed in place with silicone, although I would do that only on the outer part of the track. Leave the inside part open so moisture can escape.
Old 08-15-2016, 09:43 AM   #3
skydivingcat
I will look for different doors. The first one that I looked at the installation manual said must drill into curb.
David
Old 08-15-2016, 03:03 PM   #4
Premier Designs
Nope. As K man says .... do not screw anything into the curb, regardless of what anyone says. Silicone only.
www.premierdesigns4u.com
Premier Designs is offline   Reply With Quote
Old 08-20-2016, 07:17 AM   #5
skydivingcat
Does it mater which order the drywall and the foam pan goes in? By framed opening is 60 inches wide and the pan is 60 inches wide. Do I put the pan in first then drywall above that or do I put the drywall up and apply kerdi then cut the pan to the correct with and install?
David
Old 08-20-2016, 07:56 AM   #6
Either will work, but I'd probably put the pan in last to minimize the amount of time spent on top of it. Some installers elect to tile and grout the walls before every setting the pan. It's easy enough to do, but since the pan is a specific height, you'll want to plan carefully when setting the first row of tile (which is actually the second row up from the floor).
Old 08-23-2016, 10:02 AM   #7
skydivingcat
Not related to my project but local college just finished a cool tile project.
David
Old 02-06-2018, 09:52 AM   #8
skydivingcat
Back on this project and ready for slc on the floor. On the rest of the basement I used TEC. HD has Custom Building Products and Henry 555. Which one of those would you use?
David
Old 02-06-2018, 10:41 AM   #9
houndzilla
Boooo
K-State sucks! Jayhawks for life!
On a related note, check out my basement bathroom project, I've asked and answered a lot of the questions you have asked or will probably ask. I also have posted some architectural details that may be of help to you in getting this figured out.
George
houndzilla is offline   Reply With Quote
Old 02-06-2018, 10:56 AM   #10
LevelPro works pretty well, available at HD.
Old 02-15-2018, 06:52 AM   #11
skydivingcat
Level Pro worked good now ready for walls.
I am planning on use Laticrete 317 for the areas where the durock membrane is. Can I use this thinset for the rest of the wall tile where is being applied to drywall or should I switch to a modified thinset? Same question for the floor where the pan is durock membrane and the rest of the floor is concrete.
David
Old 02-18-2018, 06:59 PM   #12
skydivingcat
Couple more questions
Transition from durock to drywall do I use thinset of drywall mud?
Do I need to tape the durock prior to installing the membrane?
David
Old 02-18-2018, 07:24 PM   #13
You can use the 317 for all those applications, but you could also use a modified thinset mortar and probably find it a bit easier to use. USG finally came to their senses and said you could use either modified or unmodified mortar for installing and tiling over their Durock Shower Membrane, which made abundant good sense given that they require a modified mortar for use over their own Durock cement board.
Some Versabond from Homer's should be easy to source and serve the purposes.
Your transition from CBU to drywall must be outside the wet area and drywall mud is fine for finishing such joints.
You do not want to fill or tape any CBU joints to be covered with your Durock waterproofing membrane.
Old 02-18-2018, 09:25 PM   #14
skydivingcat
Thanks for the help
One more
Should I prime the drywall or leave it bare?
David
Old 03-17-2018, 08:10 AM   #15
skydivingcat
Help
Started the membrane install last night. Used Versabond mixed with 6 qts of water which was the high amount on the instructions. Used 1/8 x 1/8 trowel to spread out the thinset then used a magnesium float to embed the membrane into the thinset. This morning i went to cut out the niche and the membrane was not bonded to the thinset at all.
David
BBB - Bob's Basement Bathroom MileHighBob Tile Forum/Advice Board 19 01-31-2016 08:31 PM
Basement Bathroom John28 Tile Forum/Advice Board 13 01-06-2014 10:36 PM
Basement Bathroom kennyksu Tile Forum/Advice Board 14 12-13-2012 09:24 AM
Basement Bathroom catmandu1999 Tile Forum/Advice Board 3 01-20-2011 01:33 PM
Basement bathroom Eben Tile Forum/Advice Board 4 09-21-2009 01:35 PM
