Old 09-01-2017, 07:19 PM   #16
Vmaxman
Got a little bit of a start this week. Kerdi is up. Better bench is mounted and filled with deck mud.
I've got a couple questions.
1. My tile is 12x24x11/32 thick. Is 1/2" quadec appropriate for 11/32 tile?
2. Does this deck mud seem like it's mixed properly? Photos below. Its TEC mud bed mix for the better bench. It seemed VERY dry. I had to cover the holes in my bench frame while packing it in to keep it from falling out. It would form a ball but crumble easily. I want to make sure I'm doing it right before I make the shower base.
3. Do I need to run kerdi on top of the bench?
Sent from my SM-G930V using Tapatalk
PGH, PA
Vmaxman is offline   Reply With Quote
Old 09-01-2017, 08:17 PM   #17
Looks like deck mud to me, Mike. I usually toss a bit of thinset mortar in a small batch of such mud and add a touch more water to do the front of those benches. And frequently I screw some expanded metal mesh on the front, specially if I'm making the front a little bigger to accommodate a particular tile pattern request.
I also always cover the top and front with whatever waterproofing membrane I'm using. Not required, but I think it best to keep water out of that little mud bed.
Your bench looks good if you remembered to slope it to drain.
Old 09-02-2017, 07:00 AM   #18
Vmaxman
Thanks CX.
The bench has about 1/8" of slope.
I mixed a slurry of 272 and covered the front with it. Let it set up a bit while I mixed up the deck mud and filled the seat. Once the seat was filled, I added a little water to the rest of my bucket and filled the front.
PGH, PA
Old 09-07-2017, 05:21 PM   #19
Vmaxman
Just not enough time in the day...
Got a little bit of a start on it.
PGH, PA
Old 09-07-2017, 06:15 PM   #20
As long as you're moving forward, that's what counts. The last thing you want have to do is fix mistakes because you went too fast.
Old 11-05-2017, 12:49 PM   #21
Vmaxman
Little more progress
PGH, PA
Old 11-30-2017, 10:27 AM   #22
Vmaxman
My wife and I are trying to decide on grout color . Is it possible to mix up tiny batches of Spectralock to make some test boards?
I'm buying a commercial unit of A&B. Then a 4 different colors of part C. I'd rather not waste a bunch of expensive grout for test boards. Can I divy up a full unit to make micro batches?
PGH, PA
Old 11-30-2017, 10:57 AM   #23
rmckee84
Ive been told if you need to split units to make smaller batches that the best practice is to weigh and separate them.
Ryan McKee
Old 12-31-2017, 09:57 AM   #24
Vmaxman
Finally got some time to work on this again. The tile is in. Just need to grout now.
PGH, PA
Old 03-11-2018, 06:47 PM   #25
Vmaxman
Grout was done awhile back. Figured I'd update with some photos.
I appreciate the advice, and the forum as a whole. It's a great resource. Thank you!
PGH, PA
Old 03-11-2018, 06:53 PM   #26
Looks very nice, Mike.
I just did that very same tile in a shower remodel last fall.
Old 03-11-2018, 07:23 PM   #27
makethatkerdistick
Looks great. Is this Schluter Quadec for framing the niche?
Wolfgang
Old 03-14-2018, 06:11 PM   #28
Vmaxman
Yes, brushed stainless Quadec.
PGH, PA
Mike's Steam Shower Build CountryBumkin Tile Forum/Advice Board 136 01-07-2016 10:45 AM
Mike's Bathroom Remodel moveright Tile Forum/Advice Board 9 08-05-2011 11:42 AM
Mike's Steam Shower Build mccj Tile Forum/Advice Board 72 08-21-2010 01:33 PM
mike's bathroom reno marsman Tile Forum/Advice Board 5 03-25-2007 10:00 PM
Mike's Bathroom Project Mike_Snyder Tile Forum/Advice Board 25 01-18-2007 07:38 PM
