Old 03-01-2014, 04:21 PM   #1
kdenault
In floor radiant heat...rpm mats
So I will be installing radiant heat wire in a sunroom addition which houses at swim spa. The substrate is Advantech over crawl space. The slab of the crawl space was spray foamed. The walls of the crawl space and the room are also spray foamed, as well as the ceiling. The room will be heated with a dedicated ductless mini split system. I will be laying down the rpm mats, the wire, grommets, then bonding agent, then SLC, then thinset (modified?), then the tile. The tile is a combination of jade pebble tile and stainless steel pebble tile (stainless wrapped over ceramic base). The tile are set on mosaic mesh. I plan on using an epoxy grout.
The questions:
1. Is any particular SLC recommended for applications with electric in floor radiant heating?
2. I've read different things about the need for an uncoupling membrane or anti-crack membrane on top of the SLC. Not sure if it's needed here as the tile is "pebble" pieces. But, I did read that one needs to wait about 30 days for the SLC to cure before setting tile. Don't really want to do that! In speaking with the rpm mat people, they said nothing else is needed other than what I mentioned above.
Any thoughts?
Thanks in advance,
Kathleen
kdenault is offline   Reply With Quote
Old 03-01-2014, 04:35 PM   #2
jondon
jondon's Avatar
posted by Kathleen:
The questions:
Hi Kathleen
1) There are quite a few SLC brands out there. Personally I use Laticrete NXT Level if you can get it. Big box stores don't carry it. With any Leveler use exact amount of water when you mix and block off perimeter and any holes or cracks in the floor. This stuff flows and will flow through a thin crack.
2)not sure where you heard about waiting 30 days for SLC that applies to fresh concrete. You can tile same day on SLC if it is rapid set and next day if it is not. As for a membrane on top of the SLC you can't use pebbles on top of some of those uncoupling membranes so look into that. You could put a liquid crack isolation over the SLC. You need a very flat surface to tile pebbles onto.
Jon Donmoyer
JD Tile
CTEF Certified Installer #825
Old 03-01-2014, 04:39 PM   #3
Richard Tunison
Retired Tile Contractor
I'd love to see a picture of the pebble tiles you chose. They sound very interesting.
Richard
Richard Tunison is offline   Reply With Quote
Old 03-01-2014, 04:46 PM   #4
kdenault
Smile
Well...the tile is going to be a self-made blend of the white jade and stainless steel pebbles: cutting some white pebbles out of the mesh backing and inserting stainless pebbles randomly...we'll see how it works!
Kathleen
Old 03-01-2014, 04:48 PM   #5
kdenault
Jon,
I guess my question is really more about whether or not a form of crack isolation over the SLC is necessary? Could I just thinset right over the SLC and tile?
Kathleen
Old 03-01-2014, 05:00 PM   #6
Welcome back, Kathleen.
Choose any major brand of SLC that you find readily available in your area. Whatever you choose, I would recommend you contact the manufacturer directly and ask specifically about using it over the RPM mat.
I personally would not install ceramic or natural stone tile over a radiant heating system without an uncoupling or anti-fracture membrane, but I know it's done regularly. With your pebbles and epoxy I don't know what problems you might anticipate, but I'd be happy to pay a premium not to find out.
Old 03-01-2014, 05:28 PM   #7
kdenault
Cx,
What membrane would you recommend and what would be the typical installation method for it?
Kathleen
Old 03-01-2014, 05:48 PM   #8
jondon
jondon's Avatar
Kathleen, what size are the pebbles? That will determine what you can use as for an uncoupling membrane, you might need to use a liquid crack isolation liquid which imo would be the best over slc since it would be very flat. The uncoupling membranes have a minimum size requirement. Let me check that out, personally I would use a liquid paint on over the slc and there are many of those out there.
Jon Donmoyer
JD Tile
Old 03-01-2014, 05:52 PM   #9
jondon
jondon's Avatar
check out this thread, answers your question of min. 2X2 over ditra
John used greenskin over his slc for these mosaic tiles, a nice option
http://www.johnbridge.com/vbulletin/...d.php?t=111712
Jon Donmoyer
JD Tile
Old 03-01-2014, 06:00 PM   #10
I would recommend a good sheet-type membrane like NobleSeal, installed with one of their proprietary adhesives, such as NobleBond EXT. Perfectly acceptable for your small stone tiles.
Old 03-02-2014, 04:39 PM   #11
kdenault
Would RedGuard be suitable or should I go with something more like Greenskin? My pebble tiles are fairly large...smallest being about 1 1/2 inches. I prefer a single step process but want something effective. Also, one of the borders of the floor area that will be heated, slc'ed, and then tiled, is a newly built cedar deck (housing the swim spa). I'm a little concerned about running the SLC and then the thinset right up to the cedar due to the wood's inherent contraction/expansion/movement. Is there something that I can use to create a nice clean barrier between the tiling system and the cedar?
Kathleen
Old 03-02-2014, 04:53 PM   #12
Topspin
SchluterUgrad
Topspin's Avatar
Caution: RPM acts like* a waterproof barrier with 5/16" or 1/2" SLC on top. Putting another waterproof barrier over that may create a moisture sandwich. Contact Mike at RPM and your separation layer mfgr for guidance.
* "like" meaning that for each 5 sq ft RPMmat/sheet, it is waterproof all but the seams. So large areas are a sandwich - so itsa judgment call.
I feel that the RPM mat would have similar qualities as the method used with the Ditra-e heat. Separation layer just under the RPM with heat and tile above.
Old 03-02-2014, 05:49 PM   #13
kdenault
Yeah...in my chats on Master Warehouse (distributor of RPM mats...not sure of this is Mike or not???)...they said that an uncoupling membrane is not needed. Just SLC, thinset, and tile. I guess my concern was more about what was needed on top of the SLC and not what was underneath it. I just don't want to make a mistake with this
Kathleen
Old 03-03-2014, 07:42 PM   #14
kdenault
So Kevin...I should be ok with adhering the TPM mats to the Advantech subfloor, lay the wire, spray bonding agent, SLC, thinset and tile. Waterproofing is dealt with by the RPM mats...don't want a moisture sandwich! Do you think potential cracking is still an issue that needs to be addressed?
Kathleen
Old 03-05-2014, 05:11 AM   #15
kdenault
Bostik Dimension, Star Glass, or just glitter in grout???
I am laying a tile floor with electric radiant heat in a spa room. I am using a self made blend of large jade flat pebbles and stainless steel wrapped ceramic pebbles set on mesh. I would like to bring in some more color (to echo the cedar deck around the spa) with the grout. I particularly like the copper epoxy grout from Bostik Dimension line, which bought out Star Glass grout several years ago. However, I am not using glass tile so the translucent quality of the Dimension grout will be a bit unrealized although I really do like that bit of sparkle it has from the minute glass spheres of which it consists. My issue is that Dimension is quite pricey (around $100 per 9 oz premixed container). With about 240 sq ft to tile and grout...this is a bit much!
I have read about using grout as an additive when mixing epoxy grout (SpectraLock???) or simply adding it to regular grout.
Does anyone have any opinions on which is the preferred method to add a little sparkle to the grout...I know the purists are probably grimacing, but this is a fun unique space that calls for a fun and unique design.
Kathleen
Kathleen
RPM Mats Curley Tile Forum/Advice Board 17 05-30-2012 11:02 PM
RPM Mats v. Ditra for radiant floor Bob Casey Professionals' Hangout 31 09-12-2011 01:45 PM
Radiant Positioning Mats (RPM) Sherri Tile Forum/Advice Board 0 01-25-2010 06:45 PM
RPM Mats The Kid Professionals' Hangout 24 06-02-2009 08:37 PM
Unlevel slab with radiant heat mats Pondguy427 Tile Forum/Advice Board 1 03-27-2005 11:30 PM
