Old 02-04-2014, 02:25 AM   #1
dhagin
Seeking info on Kerdi shower failures
I'm talkin shower failures where Kerdi was used as the primary waterproofing. Anyone seen or heard of any? Any age, any approved substrate, anything? Thanks.
dana
Old 02-04-2014, 05:27 AM   #2
I've done quite a few, maybe 75 or so, probably not as many as other pros here. Got two in my own house. None have failed yet, to my knowledge.
Old 02-04-2014, 07:05 AM   #3
koihito
No one of consequence.
koihito's Avatar
I've never seen a failed one.
Nate
No one of consequence...
www.mikoskiconstruction.com
Old 02-04-2014, 07:26 AM   #4
mullet
mullet's Avatar
How many have replaced a shower because the new home owner didn't like the layout or tile and there was kerdi underneath? I am thinking about using Kerdi for my shower project coming up.
chuck
my first Kerdi Shower
Old 02-04-2014, 07:32 AM   #5
Tiger pilot
Location: Atlanta Georgia, but working across North America
What Schluter has done, better than anyone else in our industry, is spend the time and money to provide the best training that proves when you follow their instructions on installing their products you stop all chances of failure.
Is this true of most all other products? Yep, most likely, HOWEVER, no other mfg has invested in a program like Schluter. As a reward installers choose to use Schluter products and made them a true leader in our industry.
Unwavering focus on quality and training has paid off well for everyone!
Steve
Steve Rausch
Professional Consultant to Tile Industry
Cell 404-281-2218
Rauschsteve@comcast.net
Tiger pilot is offline   Reply With Quote
Old 02-04-2014, 07:37 AM   #6
Eschbach
Tile Contractor-Virginia
I have never heard of any in my area.I use Schluter everyday and it has treated me well.
www.eschbachrenovations.com
Virginia Installer of Schluter Kerdi and Kerdi Board Waterproof Showers
Excellence is no accident
Eschbach is offline   Reply With Quote
Old 02-04-2014, 08:07 AM   #7
If we were gonna hear about such failures, 'specially from a third party, I would expect it to be right here on this website. Anyone in the industry would likely know just where to go to start bashing that product or just to report factually on a product failure.
We've heard of one where the foam tray was moving and the floor failed, but the shower owner declined to allow Schluter to be present for the demolition to determine just what happened there. And we've heard of the steam shower failure where the steam plumbing was installed next to the Kerdi Board, but that sure wouldn't count as a Schluter or Kerdi failure in my book.
I know of no actual failures. I own only a few and the oldest has seen only about five years of service. All are remodels in houses I built years ago and my customers do know how to contact me.
Old 02-04-2014, 10:00 AM   #8
dhagin
I remember those 2 instances CX, and wouldn't consider them Kerdi failures or even Kerdi Shower failures either. Did a search here and found nothing even pointing to one.
dana
Old 02-04-2014, 11:17 AM   #9
Cain
Cain
I saw one fail, homeowner hired a landscape guy to do her shower, he had no clue what kerdi was, he tried to re use the clamping drain. When she asked for a flood test, she got a new ceiling downstairs.
not kerdi s fault
Cain Curtis
A Tile Experience
Certified Tile Installer #362
Cain is offline   Reply With Quote
Old 02-07-2014, 07:42 PM   #10
dhagin
B
u
m
p
Just seein if anyone else has seen or heard or any failures. Any. Thanks for lookin in.
dana
Old 02-07-2014, 08:33 PM   #11
Higher Standard Tile
Tile and Stone Contractor
Higher Standard Tile's Avatar
Dana, just curious as to why you are asking?
I assume somebody said they fail all the time and you are trying to prove them wrong.
I haven't done a ton of Kerdi showers but have not had any failures. Found a leak after a flood test but corrected it before tiling.
It is is like most of the quality products on the market, if installed correctly it will work, if installed incorrectly it will fail.
Isaac
Higher Standard Tile & Stone
Maui, Hawaii
Old 02-07-2014, 08:35 PM   #12
Lump
Lump's Avatar
What I can tell you is IF the kerdi system ever starts to fail I am moving very very far away because there will be many many people after me.
Brad L. Lenz
NTCA Proud Member
Old 02-07-2014, 08:45 PM   #13
Westside1
Just like any system we have seen multiple failures. ALL of them have always been installer related. I have never need a failure of any Schluter product that was directly related to the product failing as opposed to the installation of the product causing the failure.
As others have stated, i'm sure if failures were out there, they'd be documented somewhere on this forum.
Mathew
Westside1 is offline   Reply With Quote
Old 02-08-2014, 12:47 AM   #14
Swedes Tile
Swedes Tile's Avatar
All failures are usually installer related with any shower!
Swedes Tile is offline   Reply With Quote
Old 02-08-2014, 01:31 AM   #15
I have seen one. Just recently. But it appeared to be consistent with a combination of three errors or deficiencies.
1) The "drain hole" cut through the wood subfloor was quite over-sized compared to the body of the Kerdi drain. Two inches to be exact.
2) The substrate below the foam pan was only diagonal 1x8 solid dimensional boards...no plywood. And
3) One of the centermost 1x8 boards was cracked in half so severely that it was drooping down into the basement at 30 degrees from the horizontal plane of the floor.
This all resulted in excessive deflection of the floor tiles. It was about 5 years old. It wasn't leaking, but a few mosaic tiles had come loose.
Weekend warrior seeking Kerdi shower advice ntheath Tile Forum/Advice Board 210 10-30-2014 01:02 PM
Seeking info and advice on building entire tub of tile j delong Tile Forum/Advice Board 6 03-17-2010 11:52 PM
Seeking Kerdi/glass mosaic advice bricoz Tile Forum/Advice Board 7 02-15-2010 08:47 AM
Seeking pro with Kerdi experience in Westchester NY esb2000 Professionals' Hangout 4 09-27-2007 07:36 AM
carpenter seeking kerdi advice titmas Professionals' Hangout 22 11-28-2006 05:16 PM
