Old 01-29-2014, 05:26 PM   #1
crackrx
Kerdi Shower pan - slope issues
I installed a kerdi shower pan, but the existing floor was out of level, sloping away from the off-center drain. I used thinset to build up the side that was pitched incorrectly. The problems began, when in my haste to get kerdi fabric on the wall I was stepping on the freshly set shower pan. It caused the intersection of the two pre-pitched foam pieces to sink. I did not notice until after I had all the kerdi fabric on.
My question is, what is the best way to go about correcting the dip and improper pitch. Can I use deck mud over the kerdi, and then apply another layer of kerdi? Can I try and level it out using thinset, and then apply tile after that. Any help would be much appreciated.
-Casey
Casey
crackrx is offline   Reply With Quote
Old 01-29-2014, 06:18 PM   #2
Lazarus
Lazarus's Avatar
To a certain extent, a medium bed thinset may correct the problem. Regular thinset is limited to about 1/4" build up.....
Laz...
Old 01-29-2014, 06:29 PM   #3
crackrx
I am seeing conflicting things. Is Ditra set considered a medium set or a thin set? If medium set would Ditra set work?
Casey
Old 01-29-2014, 06:37 PM   #4
Lazarus
Lazarus's Avatar
Ditra is NOT a "morter." It is an isolation membrane...........
Laz...
Old 01-29-2014, 06:43 PM   #5
crackrx
Gotcha, but I was referring to Ditra Set mortar, by bostik.
Casey
Old 01-29-2014, 06:47 PM   #6
crackrx
Nevermind, found the spec sheet for it. It says "Portland cement thin set mortar and Medium bed mortar for schluter -ditra uncoupling membrane"
So that should be good to go, right?
Casey
Old 01-29-2014, 06:49 PM   #7
According to my Schluter rep, Ditraset is a medium set mortar
Old 01-31-2014, 02:00 PM   #8
jm66210
Why don't you just tear that foam tray out & float a pan using deck mud. Trying to create a slope with thinset mortar sounds like going from bad to worse. As the saying goes...Haste makes waste...
Jim
jm66210 is offline   Reply With Quote
Old 01-31-2014, 02:20 PM   #9
Welcome, Casey.
What Jim said.
All bonding mortar manufacturers in the ceramic tile industry, and the industry itself, specifically state that thinset mortar (including medium-bed) are not to be used for leveling or truing the substrate.
Recessed Shower Pan Issues joshr2169 Tile Forum/Advice Board 45 11-30-2015 07:34 PM
Shower door to drain not enough slope, kerdi pan PhilCO Tile Forum/Advice Board 20 06-27-2013 10:16 AM
shower pan install issues tanglewoodtree Tile Forum/Advice Board 8 05-17-2012 12:55 PM
KBRS Shower Slope/Pan Over Old Pan nsoldon Tile Forum/Advice Board 8 02-07-2011 10:32 AM
shower pan issues bkfowler Tile Forum/Advice Board 9 08-30-2004 06:10 AM
